Hello.
I get garbled noise when I play Masters (MQA) songs from Tidal via Audirvāna Studio. The same song plays just fine on the Tidal App.
I’m using Audirvāna Studio on a 2020 Macbook Pro, connected to the iFi Zen One Siganture DAC (it supports MQA).
Apple Midi settings are set appropriately to 2 ch stereo output via the iFi DAC. Format 32-bit 384KHz
Auto Detect MQA Devices is turned on and is in MQA Decoder mode (Cannot change that).
The upsampling on Audirvāna is set to off. No signal processing. No Volume Levelling.
I searched the forum and found that setting the upsampling to off was the proposed solution, which I already have.
Can someone be so kind as to help or let me know what I am doing wrong?
The debug info from Audirvāna is below
"Audirvana Studio 1.12.2 (11202)
macOS Version 12.3 (Build 21E230) with 16GB physical RAM
Connected account of : Nik Nag
- Polarity Inversion:*
Globally: OFF* -
Per track: OFF* - Effects plugins NOT ACTIVE*
- r8brain not in use*
- r8brain filter parameters*
- Bandwidth = 99.5%*
- Stop band attenuation 218dB*
- Phase linear*
- Max allowed volume: 100*
- Replay Gain: None*
- SW volume control: ON*
Sync list: 1 folders*
AUTO: /Volumes/Samsung_T5/Lossless* -
iTunes/Music library synchronization: last synchronized on Sat Apr 16 08:48:47 2022*
Library database path: /Users/nyx/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite*
- Listening on 127.0.0.1 on port 55811*
- Qobuz: Connected as Qobuz Studio*
- TIDAL: Connected as HIFI*
- Exclusive access: Disabled*
- Integer mode: Enabled*
*Preferred device: *
- IFI (BY AMR) IFI (BY AMR) HD USB AUDIO *
- Model UID:iFi (by AMR) HD USB Audio:20B1:3009*
- UID:AppleUSBAudioEngine:iFi (by AMR):iFi (by AMR) HD USB Audio:0025:1*
- Sample rate limitation: none*
- Sample rate switching latency: none*
- Limit bitdepth to 24bit: OFF*
- Mute during sample rate change: OFF*
- Local audio device*
- ID 0x119 iFi (by AMR) HD USB Audio *
- Manufacturer: iFi (by AMR)*
- Model Name: iFi (by AMR) HD USB Audio *
- Model UID: iFi (by AMR) HD USB Audio:20B1:3009*
- UID: AppleUSBAudioEngine:iFi (by AMR):iFi (by AMR) HD USB Audio:0025:1*
- 44100*
- 48000*
- 88200*
- 96000*
- 176400*
- 192000*
- 352800*
- 384000*
Audio buffer frame size : 14 to 4096 frames - Current I/O buffer frame size : 512*
Volume Control - Physical: Yes*
- Virtual: Yes*
MQA capability - Auto-detect MQA devices: Yes*
- MQA Decoder device*
Device audio channels - Preferred stereo channels L:1 R:2*
- Channel bitmap: Ox3, layout:*
Channel 0 mapped to 0* -
Channel 1 mapped to 1*
- Number of channels: 2*
- Use as stereo device only: No*
- Simple stereo device: Yes*
- Number of active channels: 2, in 1 stream(s)*
Channel #0 :Stream 0 channel 0* -
Channel #1 :Stream 0 channel 1*
Stream ID 0x11a 2 channels starting at 1
32 virtual formats:
- 2 ch Mixable linear PCM Interleaved 32 little endian Signed Float 384kHz*
- 2 ch Mixable linear PCM Interleaved 32 little endian Signed Float 352.8kHz*
- 2 ch Mixable linear PCM Interleaved 32 little endian Signed Float 192kHz*
- 2 ch Mixable linear PCM Interleaved 32 little endian Signed Float 176.4kHz*
- 2 ch Mixable linear PCM Interleaved 32 little endian Signed Float 96kHz*
- 2 ch Mixable linear PCM Interleaved 32 little endian Signed Float 88.2kHz*
- 2 ch Mixable linear PCM Interleaved 32 little endian Signed Float 48kHz*
- 2 ch Mixable linear PCM Interleaved 32 little endian Signed Float 44.1kHz*
- 2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 384kHz*
- 2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 352.8kHz*
- 2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 192kHz*
- 2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 176.4kHz*
- 2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 96kHz*
- 2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 88.2kHz*
- 2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 48kHz*
- 2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 44.1kHz*
- 2 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer 384kHz*
- 2 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer 352.8kHz*
- 2 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer 192kHz*
- 2 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer 176.4kHz*
- 2 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer 96kHz*
- 2 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer 88.2kHz*
- 2 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer 48kHz*
- 2 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer 44.1kHz*
- 2 ch Non-mixable linear PCM Interleaved 16 little endian Signed Integer 384kHz*
- 2 ch Non-mixable linear PCM Interleaved 16 little endian Signed Integer 352.8kHz*
- 2 ch Non-mixable linear PCM Interleaved 16 little endian Signed Integer 192kHz*
- 2 ch Non-mixable linear PCM Interleaved 16 little endian Signed Integer 176.4kHz*
- 2 ch Non-mixable linear PCM Interleaved 16 little endian Signed Integer 96kHz*
- 2 ch Non-mixable linear PCM Interleaved 16 little endian Signed Integer 88.2kHz*
- 2 ch Non-mixable linear PCM Interleaved 16 little endian Signed Integer 48kHz*
- 2 ch Non-mixable linear PCM Interleaved 16 little endian Signed Integer 44.1kHz*
48 physical formats
- 2 ch Mixable linear PCM Interleaved 32 little endian Signed Integer 384kHz*
- 2 ch Mixable linear PCM Interleaved 32 little endian Signed Integer 352.8kHz*
- 2 ch Mixable linear PCM Interleaved 32 little endian Signed Integer 192kHz*
- 2 ch Mixable linear PCM Interleaved 32 little endian Signed Integer 176.4kHz*
- 2 ch Mixable linear PCM Interleaved 32 little endian Signed Integer 96kHz*
- 2 ch Mixable linear PCM Interleaved 32 little endian Signed Integer 88.2kHz*
- 2 ch Mixable linear PCM Interleaved 32 little endian Signed Integer 48kHz*
- 2 ch Mixable linear PCM Interleaved 32 little endian Signed Integer 44.1kHz*
- 2 ch Mixable linear PCM Interleaved 24 little endian Signed Integer 384kHz*
- 2 ch Mixable linear PCM Interleaved 24 little endian Signed Integer 352.8kHz*
- 2 ch Mixable linear PCM Interleaved 24 little endian Signed Integer 192kHz*
- 2 ch Mixable linear PCM Interleaved 24 little endian Signed Integer 176.4kHz*
- 2 ch Mixable linear PCM Interleaved 24 little endian Signed Integer 96kHz*
- 2 ch Mixable linear PCM Interleaved 24 little endian Signed Integer 88.2kHz*
- 2 ch Mixable linear PCM Interleaved 24 little endian Signed Integer 48kHz*
- 2 ch Mixable linear PCM Interleaved 24 little endian Signed Integer 44.1kHz*
- 2 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 384kHz*
- 2 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 352.8kHz*
- 2 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 192kHz*
- 2 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 176.4kHz*
- 2 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 96kHz*
- 2 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 88.2kHz*
- 2 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 48kHz*
- 2 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 44.1kHz*
Local devices found : 9
Device #0: ID 0x123 AV Receiver Manufacturer: Apple Inc. Model UID: AppleGFXHDA:0 UID: AppleGFXHDAEngineOutputDP:f803:0:{CB3D-1470-00000000} Model Name: Apple Inc. AV Receiver
Device #1: ID 0x40 Sound Blaster GC7 Speakers Manufacturer: Creative Technology Ltd Model UID: Sound Blaster GC7:041E:3271 UID: AppleUSBAudioEngine:Creative Technology Ltd:Sound Blaster GC7:0863B125B0869643:4 Model Name: Creative Technology Ltd Sound Blaster GC7 Speakers
Device #2: ID 0x34 Sound Blaster GC7 Headset Manufacturer: Creative Technology Ltd Model UID: Sound Blaster GC7:041E:3271 UID: AppleUSBAudioEngine:Creative Technology Ltd:Sound Blaster GC7:0863B125B0869643:6 Model Name: Creative Technology Ltd Sound Blaster GC7 Headset
*Device #3: ID 0x119 iFi (by AMR) HD USB Audio Manufacturer: iFi (by AMR) Model UID: iFi (by AMR) HD USB Audio:20B1:3009 UID: AppleUSBAudioEngine:iFi (by AMR):iFi (by AMR) HD USB Audio:0025:1 Model Name: iFi (by AMR) HD USB Audio *
Device #4: ID 0x109 MacBook Pro Speakers Manufacturer: Apple Inc. Model UID: Speaker UID: BuiltInSpeakerDevice Model Name: Apple Inc. MacBook Pro Speakers
Device #5: ID 0xda Reincubate Manufacturer: Reincubate Model UID: CamoAudioDevice_ModelUID UID: CamoAudioDevice_UID Model Name: Reincubate
Device #6: ID 0xcd Soundflower (2ch) Manufacturer: ma++ ingalls for Cycling '74 Model UID: com_cycling74_driver_SoundflowerDevice:Soundflower UID: SoundflowerEngine:0 Model Name: ma++ ingalls for Cycling '74 Soundflower (2ch)
Device #7: ID 0x45 Soundflower (64ch) Manufacturer: ma++ ingalls for Cycling '74 Model UID: com_cycling74_driver_SoundflowerDevice:Soundflower UID: SoundflowerEngine:1 Model Name: ma++ ingalls for Cycling '74 Soundflower (64ch)
Device #8: ID 0xe4 ZoomAudioDevice Manufacturer: zoom.us Model UID: zoom.us.zoomaudiodevice UID: zoom.us.zoomaudiodevice.001 Model Name: zoom.us ZoomAudioDevice
UPnP devices found : 1
Device #0: ID 0x0 Onkyo UID: uuid:b0393513-0013-35BB-b000-0009b0393513 Location: http://192.168.110.159:8888/upnp_descriptor_0
