Hi,
After updating to 3.5.40, I found a strange things happened as compared to the previous build. When playing Tidal for a couple songs (randomly, sometimes 2, 3, 4 songs), it looks like Audirvana stop downloading the song from Tidal no more. My fix was to completely stop, go to “Preference” → Reset all services now, turn off/on wifi (on Mac) then play again. This will make it back on working for awhile then happens again.
Is there anyway to roll back the version?
Thanks,
Audirvana Mac Version 3.5.40 (3570)
macOS 10.12.6 with 4096MB RAM
Registered to S--------
SoX to DSD128 with filter type C
AUTO: /Volumes/3TB/
iTunes/Music library synchronization: last synchronized on Wed Aug 12 18:35:42 2020
Library database path: /Users/macbook/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 3072MB
ADI-2 DAC (59740297)
Model UID:ADI-2 DAC (59740297):2A39:3FD3
UID:AppleUSBAudioEngine:RME:ADI-2 DAC (59740297):38D70DB41E035C8:2,1
Sample rate switching latency: 3s
ID 0x3b ADI-2 DAC (59740297) Manufacturer:RME
Model UID:ADI-2 DAC (59740297):2A39:3FD3 UID:AppleUSBAudioEngine:RME:ADI-2 DAC (59740297):38D70DB41E035C8:2,1
Stream ID 0x3c 2 channels starting at 1
20 virtual formats:
20 physical formats
Device #0: ID 0x2e Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:61 UID: AppleHDAEngineOutput:8,0,1,1:0
Device #1: ID 0x3b ADI-2 DAC (59740297) Manufacturer: RME Model UID: ADI-2 DAC (59740297):2A39:3FD3 UID: AppleUSBAudioEngine:RME:ADI-2 DAC (59740297):38D70DB41E035C8:2,1
