On my MacBook the stop button and pause is not functioning. Neither on Audirvana Remote or on my iPad Pro. When I press Command together with “.” (on the MacBook) then the track stops playing. But this short cut does not work on the iPad.
Any ideas??
Hello @jhmkoop,
Audirvana Studio 1.10.2 (11002)
macOS Version 12.3 (Build 21E5196i) with 16GB physical RAM
Connected account of : J H M Koop SIGNAL PROCESSING:
Polarity Inversion: Globally: OFF Per track: ON
r8brain filter parameters Bandwidth = 97.3%
Stop band attenuation 218dB Phase linear
Max allowed volume: 74.5397 Replay Gain: None
LIBRARY SETTINGS: Sync list: 1 folders
AUTO: /Users/jhmkoop/Desktop/ Klaar voor Audirvana
Library database path: /Users/ jhmkoop/Library/Application Support/ Audirvana/AudirvanaDatabase.sqlite
Remote Control server: Listening on 127.0.0.1 on port
49707
Preferred device: ARCAM ARCAM 6708E Model UID:ARCAM Arcam 6708e UID:uuid:3dcc7100- f76c-11dd-87af-0022616708e8
Currently playing to UPnP device at 32 bits 44.1kHz
UPnP device at http:// 192.168.178.222:8080/dd.xml
ID 0x0 Arcam 6708e Manufacturer: ARCAM
Model Name:
Model UID: ARCAM Arcam 6708e UID: uuid:3dcc7100-
11 available sample rates up to 192000Hz
8000 11000 11025 22000 22050 44100 48000 88200 96000 176400 192000
Volume control: No MQA capability
DSD capability: Unhandled Device audio channels
Preferred stereo channels L:0 R:1 Channel bitmap: Ox3, layout:
Channel 1 mapped to 1 Avoid RAW PCM streams: No UPnP/DLNA supported protocols:
http-get::audio/ L16;rate=44100;channels=1:DLNA.OR G_PN=LPCM
http-get::audio/ L16;rate=44100;channels=2:DLNA.OR G_PN=LPCM
http-get::audio/ L16;rate=48000;channels=1:DLNA.OR G_PN=LPCM
http-get::audio/ L16;rate=48000;channels=2:DLNA.OR G_PN=LPCM
http-get:*:audio/x-ms- wma:DLNA.ORG_PN=WMABASE
http-get::audio/x-ms- wma:DLNA.ORG_PN=WMAFULL
http-get::audio/ mpeg:DLNA.ORG_PN=MP3
http-get::audio/ mpeg:DLNA.ORG_PN=MP3X
http-get::audio/L16:*
http-get::audio/ L16;rate=11000;channels=1:
http-get::audio/ L16;rate=11000;channels=2:
http-get::audio/ L16;rate=11025;channels=1:
http-get::audio/ L16;rate=11025;channels=2:
http-get::audio/ L16;rate=22000;channels=1:
http-get::audio/ L16;rate=22000;channels=2:
http-get::audio/ L16;rate=22050;channels=1:
http-get::audio/ L16;rate=22050;channels=2:
http-get::audio/ L16;rate=44100;channels=4:
http-get::audio/ L16;rate=44100;channels=6:
http-get::audio/ L16;rate=44100;channels=8:
http-get::audio/ L16;rate=8000;channels=1:
http-get::audio/ L16;rate=8000;channels=2:
http-get::audio/L8:
http-get::audio/ L8;rate=11000;channels=1:
http-get::audio/ L8;rate=11000;channels=2:
http-get::audio/ L8;rate=11025;channels=1:
http-get::audio/ L8;rate=11025;channels=2:
http-get::audio/ L8;rate=22000;channels=1:
http-get::audio/ L8;rate=22000;channels=2:
http-get::audio/ L8;rate=22050;channels=1:
http-get::audio/ L8;rate=22050;channels=2:
http-get::audio/ L8;rate=44100;channels=1:
http-get::audio/ L8;rate=44100;channels=2:
http-get::audio/ L8;rate=48000;channels=1:
http-get::audio/ L8;rate=48000;channels=2:
http-get::audio/ L8;rate=8000;channels=1:
http-get::audio/ L8;rate=8000;channels=2:
http-get::audio/flac:
http-get::audio/x-flac: http-get::audio/wav: http-get::audio/x-wav: http-get::audio/x-ms-wma: http-get::audio/mpeg: http-get::audio/mp4: http-get::audio/m4a: http-get::audio/x-m4a: http-get::audio/m4b: http-get::audio/x-m4b: http-get::audio/x-aac:
DLNA 1.5: Yes
Gapless playback: No
Missing events workaround: No Can play native DSD: No Volume Control: scalar
Channel #0 :Stream 0 channel 0 Channel #1 :Stream 0 channel 1
Stream ID 0x0 0 channels starting at 0 25 virtual formats:
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 44.1kHz
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 48kHz
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 11kHz
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 11.025kHz
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 22kHz
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 22.05kHz
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 8kHz
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 44.1kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 88.2kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 176.4kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 48kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 96kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 192kHz finite length
0 physical formats
Current device transportInfo: CurrentTransportState: PLAYING CurrentTransportStatus: OK CurrentSpeed: 1
Current device MediaInfo: NrTracks: 1
MediaDuration: NOT_IMPLEMENTED
CurrentURI: http:// 192.168.178.108:49153/audirvana/ audio_0.pcm
CurrentURIMetadata: <DIDL-Lite xmlns:dc=“http://purl.org/dc/elements/ 1.1/” xmlns:upnp=“urn:schemas-upnp- org:metadata-1-0/upnp/” xmlns=“urn:schemas-upnp- org:metadata-1-0/DIDL-Lite/”
xmlns:dlna=“urn:schemas-dlna- org:metadata-1-0/”>
dc:titleOnce upon a time in de west</dc:title>
dc:creatorHoof, Harry van & Souer, Piet </dc:creator> upnp:artistHoof, Harry van & Souer, Piet </upnp:artist> upnp:genreEasy Listening</ upnp:genre> upnp:albumArtURIhttp:// 192.168.178.108:49153/audirvana/ artwork_0_0.jpg</upnp:albumArtURI> upnp:albumStrings bij candlelight</ upnp:album> upnp:originalTrackNumber1</ upnp:originalTrackNumber> upnp:classobject.item.audioItem.mu sicTrack</upnp:class>
nextURI: NOT_IMPLEMENTED
PlayMedium: NETWORK
<?xml version="1.0"?> 1 0 GetCurrentTransportActions InstanceID in A_ARG_TYPE _InstanceID Actions out CurrentTranspo rtActions GetDeviceCapabilities InstanceID in A_ARG_TYPE _InstanceID PlayMedia outPossiblePlayba ckStorageMedia</ relatedStateVariable>
RecMedia out PossibleRecord StorageMedia
RecQualityModes out PossibleRecord QualityModes
GetMediaInfo
NrTracks out NumberOfTrac ks
MediaDuration out CurrentMediaD uration
CurrentURI out
AVTransportUR I
CurrentURIMetaData out AVTransportUR IMetaData
NextURI out NextAVTranspo rtURI
NextURIMetaData out NextAVTranspo rtURIMetaData
PlayMedium out PlaybackStorag eMedium
RecordMedium out RecordStorage Medium
WriteStatus out RecordMedium WriteStatus
GetPositionInfo
Track out CurrentTrack</ relatedStateVariable>
TrackDuration out CurrentTrackD uration
TrackMetaData out CurrentTrackM etaData
TrackURI out CurrentTrackU RI
RelTime out RelativeTimePo sition
AbsTime out
AbsoluteTimeP osition
RelCount out RelativeCounte rPosition
AbsCount out AbsoluteCount erPosition
GetTransportInfo
CurrentTransportState</ name>
out TransportState
CurrentTransportStatus</ name>
out TransportStatu s
CurrentSpeed
out TransportPlayS peed
GetTransportSettings
PlayMode out CurrentPlayMo de
RecQualityMode out CurrentRecord QualityMode
Next
Pause
TransportPlayS peed
Previous
Seek
InstanceID
Unit in A_ARG_TYPE _SeekMode
Target in A_ARG_TYPE _SeekTarget
SetAVTransportURI
CurrentURI in AVTransportUR I
CurrentURIMetaData in AVTransportUR IMetaData
SetPlayMode
NewPlayMode in CurrentPlayMo de
Stop
InstanceID
CurrentPlayMode string NORMAL</ defaultValue>
NORMAL</ allowedValue> SHUFFLE</ allowedValue> REPEAT_ALL</ allowedValue>
CurrentTrackURI string
CurrentTrackDuration string
CurrentRecordQualityMode</ name>
string NOT_IMPLEMENTED< /defaultValue>
NOT_IMPLEMENTED
CurrentMediaDuration</ name>
string
AbsoluteCounterPosition</ name>
i4
RelativeCounterPosition</ name>
i4
A_ARG_TYPE_InstanceID</ name>
ui4 0
AVTransportURI string
string
PossibleRecordQualityModes string NOT_IMPLEMENTED< /defaultValue>
NOT_IMPLEMENTED
PossibleRecordStorageMedia string NOT_IMPLEMENTED< /defaultValue>
NOT_IMPLEMENTED
AbsoluteTimePosition</ name> string
NextAVTransportURIMetaDat a string
PlaybackStorageMedium</ name> string NETWORK</ defaultValue>
NONE</ allowedValue> NETWORK</ allowedValue>
CurrentTransportActions</ name>
string PLAY STOP PAUSE</ allowedValue> SEEK NEXT PREVIOUS</ allowedValue> X_DLNA_SeekTime</ allowedValue>
NOT_IMPLEMENTED
TransportState string NO_MEDIA_PRESENT
STOPPED</ allowedValue> PLAYING</ allowedValue> TRANSITIONING</ allowedValue> PAUSED_PLAYBACK NO_MEDIA_PRESEN T
CurrentTrack ui4 0 1 1 0
TransportStatus string OK OK ERROR_OCCURRED
A_ARG_TYPE_SeekTarget</ name>
string
http:// www.arcamradio.co.uk 1103020a1c0d1f2701 012805ffff93ff uuid:3dcc7100- f76c-11dd-87af-0022616708e8</ UDN>
image/png 48 48 32 /icon.png
image/jpeg 48 48 32 /icon.jpg
urn:upnp- org:serviceId:AVTransport AVTransport/scpd.xml</ SCPDURL> AVTransport/control</ controlURL> AVTransport/event</ eventSubURL>
urn:schemas-upnp- org:service:ConnectionManager:1</ serviceType>
urn:upnp- org:serviceId:ConnectionManager</ serviceId> ConnectionManager/ scpd.xml ConnectionManager/ control
ConnectionManager/ event
urn:schemas-upnp- org:service:RenderingControl:1</ serviceType>
urn:upnp- org:serviceId:RenderingControl</ serviceId> RenderingControl/ scpd.xml RenderingControl/ control RenderingControl/ event
<dlna:X_DLNADOC xmlns:dlna="urn:schemas-dlna-
org:device-1-0">DMR-1.50</ dlna:X_DLNADOC> pnpx:X_hardwareIdVEN_2A2D&am p;DEV_0001&SUBSYS_0001&a mp;REV_01 VEN_0033&DEV_0006&RE V_01</pnpx:X_hardwareId> pnpx:X_compatibleIdMS_DigitalMe diaDeviceClass_DMR_V001</ pnpx:X_compatibleId> pnpx:X_deviceCategoryMediaDevic es</pnpx:X_deviceCategory> df:X_deviceCategoryMultimedia.DM R</df:X_deviceCategory> <microsoft:magicPacketWakeSupport ed>0</ microsoft:magicPacketWakeSupported > <microsoft:magicPacketSendSupporte d>1</
microsoft:magicPacketSendSupported >
fsns:X_FeaturesDiracIO-50000</ fsns:X_Features>
UPnP devices found : 2
Device #0: ID 0x0 DP-UB9000/9004 UID: uuid:4D454930-0100-1000-8000- B46C472D2E0E Location: http:// 192.168.178.227:60606/ B46C472D2E0E/Server0/ddd
Device #1: ID 0x0 Arcam 6708eUID: uuid:3dcc7100- f76c-11dd-87af-0022616708e8 Location: http://192.168.178.222:8080/ dd.xml
Max. memory for audio buffers: 4818MB
Exclusive access: Enabled Integer mode: Enabled
Device #0: ID 0x36 MacBook Pro luidsprekers Manufacturer: Apple Inc. Model UID: Speaker UID: BuiltInSpeakerDevice Model Name: Apple Inc. MacBook Pro luidsprekers
Can you go in your device settings in Audirvāna Studio and enable the option to not send RAW PCM stream?
That works, but not completely. 1) “no RAW” is a work around, no real fix 2) When pressing the space bar, the music pauses. but there is no way to start it playing again (f.e. pressing the space bar again does nothing). Waiting for your reply
J H M Koop
Antoine,
please reply about the “workaround” and the “space bar”
It’s not a workaround. It means your device can’t play raw pcm which is not the case with every device, this is why we made this option available.
Can you send your debug info again after you try to press space bar again? I’m using a Mac with Big Sur to a Devialet device and when I press space bar again, the music is playing normally.
Antoine,
- “No RAW”: then there is something wrong in my device (settings?) or with my understanding of the manual of the device. I’ll have to look into that. But as you said: this is no work around
- I’ll send you the debug info (“after repressing the space bar) in a few days.
Thanks a lot
Joost
It’s the UPnP implementation of your device that have an issue to play raw pcm stream. You can’t do anything about it, it’s on your device manufacturer hands. You can ask them if they have a firmware update of your device available or report them your issue so they can take a look at it. If you send them a mail, you can add our mail [email protected] to it in case they need inputs from us.
