Stops and starts
Streaming Qobuz. Songs play for about ten seconds and then stops for around ten seconds. Then plays again and stops. Keeps doing this. On some tracks the starts and stops grow shorter and then it plays continuously. On others— just stops and starts. It did this on a previous device and I uninstalled and reinstalled and it fixed the problem. Just did the same on this device and still—stops and starts in exactly the same way it did on my previous device before reinstalling fixed it.???
Hello @mikearnopol,
Can you send us a copy of the ā€œDebug Infoā€ when you have this issue? You can get it in Audirvana Settings>My account
Audirvana Studio 2.2.7 (20208)
Windows 10 (19044) with 4GB physical RAM
Connected account of : Michael Arnopol
	VST3 plugin #0: C:\Program Files\Common Files\VST3\FabFilter Pro-Q 3.vst3
		ClassID: 72C4DB717A4D459AB97E51745D84B39D
	VST3 plugin #1: C:\Program Files\Common Files\VST3\Ghz CanOpener Studio 3.vst3
		ClassID: 5653544353335867687A2063616E6F70
	VST3 plugin #2: None
	VST3 plugin #3: None
Sync list: 2 folders
AUTO: C:\Users\W1\Documents
AUTO: C:\Users\W1\Music
Library database path: C:\Users\W1\AppData\Local\Audirvana\Audirvana\AudirvanaDatabase.sqlite
Listening on 192.168.1.181 on port 52255
Max. memory for audio buffers: 256MB
Local Audio Engine: WASAPI
Model UID:
UID:
Device: 2ch 32bits Integer, 8 bytes per frame 96kHz
Active Sample Rate: 96kHz
Selected device:SPDIF ęŽ„å£ (YLM HD USB AUDO)
Manufacturer: Microsoft
Model name: YLM HD USB AUDO
Model UID: USB\VID_262A&PID_9227&REV_0001&MI_01
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{92d07608-ac9b-439f-9134-857cfa074144}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
USB Vendor ID: 0x262a
USB Product ID: 0x9227
Simple stereo device: No
2 ch Integer PCM 24bit little endian 352.8kHz
2 ch Integer PCM 24bit little endian 384kHz
Device #0: SPDIF ęŽ„å£ (YLM HD USB AUDO)
Raise the buffer size to 2000mb
Audirvana Studio 2.3.0 (20300)
Windows 10 (19045) with 4GB physical RAM
	VST3 plugin #1: None
AUTO: C:\Users\W1S\Music
Library database path: C:\Users\W1S\AppData\Local\Audirvana\Audirvana\AudirvanaDatabase.sqlite
Tracks with no MBID: 44
Listening on 192.168.1.253 on port 49733
Max. memory for audio buffers: 784MB
Model UID:
UID:
Device: 2ch 24bits Integer, 6 bytes per frame 96kHz
Selected device:数字输出 (YLM HD USB AUDO)
Manufacturer: SaviAudio
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{7f9b5a59-74d6-416b-9427-b7ad5a6aae12}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #0: 数字输出 (YLM HD USB AUDO)
Sorry— it’s doing the same thing on two different devices. I sent debug info for both.
Still a bit small, try 2000mb. Try playing without the fabfilter enabled to begin with.
Sorry, but how do I change the audio buffers?
Hi @mikearnopol
Can you please try to update to 2.3 and try to play your tracks without your plugins activated?
I have the same problem sometimes happens to me and it’s not clear why it happens, I tried different buffers from 3000mb to 6000mb, plugins do not affect this
I have been using this app for over 2 years and have actually never complained about it before, it just started happening recently
Can you post your debug info?
