Here’s the captured movie, volume knob is rendering strangely.
Mine is MacBook15,1 (MBP 15 2018).
Thank you for this report.
I’ve fixed this issue in 3.2.11 you can now update to using the “Check for updates…” command of the Audirvana Plus menu.
Thank you so much. Upgraded to 3.2.11, and I can see the issue has been fixed.
