I just received an SMSL PO100 AK DAC and I have strange behavior with Audirvana Studio 2.4.0 on macmini (late 2012). Let me explain. firstly, the DAC is automatically recognized by Audirvana, no problem on this side. Now suppose I play 4 music files from a Tidal playlist, the first is a FLAC, the 2nd is an MQA and the 3rd and 4th are FLAC again. Well, when playing the 3rd file, the green MQA light stays on, both on the application and on the DAC, same thing with the 4th song and so on, until I quit and restart the 'application.
Do you think this is normal? Thanks for your help.
Regards
Malik
Hi @Malik,
Interesting, can you send us a copy of the “Debug Info” when you have this issue? You can get it in Audirvana Settings>My account
Please find attached the behavior of Audirvana When i select automatic detection from Audirvana (note that in this case My DAC displays Blue MQA indicator witch is “MQA Studio” according to the manufacturer.
When i deselect this option and choose the option MQA decoder, the green button with MQA disappears on the bottom right side on Audirvana and on the DAC the MQA indicator turns green, which corresponds to the “MQA” option for the DAC.
I suppose as mentioned in the DAC settings that Some DACs are not correctly recognized by Audirvana.
Please give me your opinion on this situation.
Note:Please find here the debug info for this session:
Audirvana Studio 2.4.0 (20400)
macOS 10.15.7 with 16GB physical RAM
Connected account of : XXXXXXXXXXX
Bandwidth at 0dB = 99.5%
Phase = 66%
AUTO: /Volumes/Public/Shared Music
Library database path: /Users/macmini/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Tracks with no MBID: 442
Listening on 127.0.0.1 on port 60642
Max. memory for audio buffers: 15360MB
Local Audio Engine: CoreAudio
Exclusive access: ON
Integer mode: ON
SMSL SMSL USB AUDIO
Model UID:SMSL USB AUDIO:152A:85DD
UID:AppleUSBAudioEngine:SMSL:SMSL USB AUDIO:14200000:1
Device: 2ch Non-mixable linear PCM Interleaved 32bits little endian Signed Integer, 8 bytes per frame 44.1kHz
Hog Mode is on
Limit bitdepth to 24bit: ON
Selected device:SMSL USB AUDIO
Manufacturer: SMSL
Model name: SMSL USB AUDIO
Model UID: SMSL USB AUDIO:152A:85DD
UID: AppleUSBAudioEngine:SMSL:SMSL USB AUDIO:14200000:1
USB Vendor ID: 0x152a
USB Product ID: 0x85dd
ID 0x4c
MQA Decoder device
Stream ID 0x4d 2 channels starting at 1
30 virtual formats:
40 physical formats
Local devices found : 5
Device #0: ID 0x45 Sortie intégrée
Model UID: AppleHDA:88
Model name: Apple Inc. Sortie intégrée
Device #1: ID 0x51 HDMI
UID: AppleHDAEngineOutputDP:1B,3,1,2:0:{D94D-4803-01010101}
Model name: Apple Inc. HDMI
Device #2: ID 0x4c SMSL USB AUDIO
Manufacturer: SMSL
Device #3: ID 0x2c MMAudio Device
Manufacturer: MMAudio Device contributors
Model UID: MMAudioDeviceModelUID
UID: MMAudioDevice
Model name: MMAudio Device contributors MMAudio Device
Device #4: ID 0x31 MMAudio Device (UI Sounds)
Model UID: MMAudioDeviceModelUID_UISounds
UID: MMAudioDevice_UISounds
Model name: MMAudio Device contributors MMAudio Device (UI Sounds)
This is a known bug with MQA. Unless the manufacturer takes special steps to disable it (very few go to the effort and expense), once MQA processing is on, it stays on for the following files that are not MQA.
Now i’ve found how to remove MQA badge on Audirvana when not playing MQA file.
I went to the MQA Setup and disabled automatic detection of the DAC and selected “MQA Decoder” in the list.
That’s all until this bug will be solved if so.
Regards,
Malik
It is doubtful the bug, which has persisted for years, will ever be resolved by MQA, which went bankrupt and has been purchased by another company. But at least Audirvana offers a workaround.
@Jud
Indeed.
But the only thing that bothers me a little is that in Audirvana, the songs in 16/44khz come out to the DAC in 32/44khz format. Is this normal?
Regards,
Malik
P.S. see it in the screenshot joined:
You needn’t be concerned. This is called “zero padding,” where the DAC has 32 bits of processing space and the 16 missing bits are filled with zeroes.
It doesn’t change anything, any more than writing 1 as 1.00000000 changes the quantity.
