Stream from Audirvana via Tailscale and listen on remote device
The idea ist to make the local music library available i.e. via iphone in the car. For another reason I had installed tailscale on my devices. That allows to securely transfer data between devices and als remotely controll the devices and apps.
My attempt is to lead the audio stream into tailscale in order to be played on the target devices. Is there a way to attempt this? Audirvana Studio is running on a MACmini. The local music library is located on an external ssd drive usb connected to the MACmini.
I suggest that you describe a real-world use-case that encompasses the functional need for this connection protocol, and the benefits the addition of such a protocol in the context of Audirvāna playback brings to the table, and how this fits with the fundamental premise for the development of Audirvāna as a premier digital audio-engine/player… I believe you can have a similar concept in other player applications that will serve the basic functions of your suggested implementation… Describing your current listening behaviors, like streaming and local, and your rationalization for having full access to a local library, will help…
It’a an interesting proposition that Tailscale’s functionality immediately suggested - as you’re literally on the same network via Tailscale getting the output to another location endpoint would be great when away from home.
For a cost-free but not-so-optimal-workaround: at source point Jellyfin (free, open source) at the local library, access remotely via either Jellyfin or, say, an iOS app such as Finamp (also free) either connected via computer to your Tailnet or phone Tailscale vpn respectively.
Not the same as Audirvana output however.
There must be a relatively straightforward way of configuring the Audirvana output to a Tailscale endpoint device but I’ve not gone into it.. yet.
You can already control audirvana remotely via Tailscale of course and it might already work via UPnP speaker etc. (same network, innit) just haven’t tested this
I tried with Tailscale and wasn’t able to because I believe it works at the wrong network layer (at least that’s what I was told). Zerotier may work, but I haven’t tried it yet. (That is, I have it running for remote access but haven’t tried getting Audirvana to work through it.)
If you’re talking about a Sonore device running the new SonicOrbiter, perhaps they’ve done it with Tailscale, I don’t know. But then you would still have to get the iPhone remote on the same network, so maybe you still have the network layer problem and might need to explore Zerotier.
I mean, it is the obvious idea. I have a payed player that’s combining all my musical sources into one. Never mind.
Audirvana ties the output to one physical device. As it concerns, it would have to have a kind of virtual device that would allow transmission through tailscale. At another endpoint, an app should be able to work as the other end of the virtual device, allowing to redirect to a local device. Maybe at one point another instance of Audirvana could perform as sender/receiver and connect virtual devices as well as the mobile app would have the capabilities beyond remote controlling the core engine. It would be great to have your personal high res library available from almost everywhere.
I’m supposing there would have to be UPnP transmission to a remote endpoint seen as being on the same LAN, either a laptop or SBC with UPnP software and Zerotier installed. (I’m assuming Zerotier since as I noted I was told - by folks with some expertise - that Tailscale operates at the wrong network layer for this.) Then there would have to be remote control from a phone also seen as being on the same LAN.
Perhaps one of these days I’ll try it, unless you get there first. :slightly_smiling_face:
Just to add I’ve tested the Audirvana remote on iPhone via Tailscale vpn and this works.
Also the workaround ( not Audirvana, but at least a mirror an Audirvana library content) I suggested via Jellyfin and Tailscale also works - I use this occasionally when out-and-about, Finamp can play FLAC and has a high bitrate playback (I can’t remember off the top of my head the exact details but recall they’re available). Jellyfin auto-scans, this runs pretty much maintenance free.
Yep, I’ve used Airsonic or Airsonic-Advanced forever, but would be nice to have Audirvana’s upsampling options.
Thanks for the tip @Jud - I hadn’t heard of this so will take a look - Interested to see how it compares in library loading and interface vs. Finamp as it is “designed to handle very large music collections”.
Use the kagemomjii fork, it’s newest by a long shot.
Also, unless you’re already well accustomed to something else, the Caddy server makes reverse proxy with SSL dead simple.
Thanks again I’ll take a look at this
