kann wer mir helfen kann keine verbindung mit meinen streamer herstellen habe das studio
mit dem alten audirana ist das gegangen
Hello @sausebaum ,
Are you using the latest version of Audirvana Studio? Are you using a Windows 10 or MacOS computer?
Habe Windows 10 und das Studio
Can you check your connection property: In Settings > Network & Internet > Check connection properties, make sure your Network profile is set to Private.
Also, can you check the firewall settings: In Settings > Update and Security > Windows Security > Firewall and Network Protection > Allow an application through firewall, make sure that Audirvana is allowed to access the network.
