Hi! I stored Flac 24/96 and Dff (DSD64 converted) files in OneDrive in a cartel called Music. After that I have added this new folder in the settings page of my Audirvana 3.5 (Windows 10 version) … and all is running perfectly! Unexpectedly with the identical quality listening of the flacs stored in an internal SD of the notebook. But my question is if I am really listening the native file formats or OneDrive does compress them in MP3?
When you open any file stored in OneDrive that is synced with your computer the file is downloaded in your computer which means you basically have a Dff or Flac file directly stored in your computer, it’s not a mp3.
Hi Damien. Thanks a lot for your quick and clear reply!
Giuliano
