I use itunes with the latest version of audirvana(3.5) with my antelope audio audio D/A converter, it was reading at up to 192, but know ut only plays music up to 96, I have not changed anything at all? anyone else with a similar issue? Im using a 2019 IMAC with 10.15 Mojave…
Hello @lespaul32,
Can you send me a copy of the “Debug Info” while you have the issue? You can get it in Audirvana Settings>General>Debug Info
Here you go!
Audirvana Plus rev. 3.2.20 (3704) debug information:
running on Mac OS X 10.14.6 with 16384MB RAM
User preferences:
Remote control: IR: on, Media Keys: on (with volume control: on)
Playlists
Use UTF-8 for all: on
Start playback at launch with audio file: on
Volume knob control in rotation axis
Sample rate converter
iZotope SRC with Power of Two oversampling
Polarity inversion: global=off, per track=on
Volume control
SW only
Max volume limit = 100.0%
AudioUnits not in use
SysOptimizer enabled:
Priority: Extreme
Spotlight: on
TimeMachine: on
iDevices USB: on
iTunes settings:
iTunes integrated Mode: on
Completely deactivate iTunes playback: on
iTunes volume control: active
iTunes play position control: active
iTunes safe factor: 3
Library mode: off
Audio settings:
Hog Mode: on
Direct Mode: off
Integer Mode: on Mode 1
Max Mem for audio buffers: 12288MB
Max Sample rate limit: 192kHz
Sample rate switching latency: None
Preferred device: Zodiac+ Model UID:Zodiac+:23E5:0011 UID:AppleUSBAudioEngine:Antelope Audio:Zodiac+:14100000:1
ID 0x50 Zodiac+ Manufacturer:Antelope Audio
Physical (analog) volume control: No
Virtual (digital) volume control: No
Stream ID 0x51 2 channels starting at 1
8 virtual formats:
2 ch Mixable linear PCM Interleaved 32 little endian Float 96kHz
2 ch Mixable linear PCM Interleaved 32 little endian Float 88.2kHz
2 ch Mixable linear PCM Interleaved 32 little endian Float 48kHz
2 ch Mixable linear PCM Interleaved 32 little endian Float 44.1kHz
8 physical formats
Local devices found : 6
Device #0: ID 0x46 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:16 UID: AppleHDAEngineOutput:1F,3,0,1,1:0
Device #1: ID 0x50 Zodiac+ Manufacturer: Antelope Audio Model UID: Zodiac+:23E5:0011 UID: AppleUSBAudioEngine:Antelope Audio:Zodiac+:14100000:1
Device #2: ID 0x2b Quartet Manufacturer: Apogee Model UID: AppleUSBAudioDevice:Quartet UID: AppleUSBAudioEngine:Apogee:Quartet:14300000:1,2
Device #3: ID 0x38 MMAudio Device Manufacturer: MMAudio Device contributors Model UID: MMAudioDeviceModelUID UID: MMAudioDevice
Device #4: ID 0x3d MMAudio Device (UI Sounds) Manufacturer: MMAudio Device contributors Model UID: MMAudioDeviceModelUID_UISounds UID: MMAudioDevice_UISounds
Device #5: ID 0x33 Pro Tools Aggregate I/O Manufacturer: Apple Inc. Model UID: com.Avid.ProToolsAnalogIOAggregateDevice UID: com.Avid.ProToolsAnalogIOAggregateDevice
Can you go in Audio midi setup and check if you can change the maximum sample rate used by your device?
I can- i reset the zodiac- i keep noticing when i play a song in itunes, its pauses, then my output changes to another, this happens alot- if there a fix to this?
Does this happens with every track you play?
