Stuck on loading first track to play
Audirvana won’t play anymore. It used to work but no more. It gets stuck on “loading first track”
Audirvana Mac Version 3.5.46 (3576)
macOS 11.4.0 with 65536MB RAM
Registered to aubry pierre
AUTO: /Users/aubrypierre/Music/Music/Media
Library database path: /Users/aubrypierre/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Preferred device: 851N Model UID:Cambridge Audio 851N UID:uuid:07063e00-329a-4fe8-b67e-ec79480a0346
UPnP device at http://192.168.178.69:8050/07063e00-329a-4fe8-b67e-ec79480a0346/description.xml
ID 0x0 851N Manufacturer:Cambridge Audio
Volume control: No
DSD capability: Raw DSD (MSB)
http-get:
:audio/L16;rate=44100;channels=2:DLNA.ORG_PN=LPCM
http-get:
:audio/L16;rate=48000;channels=2:DLNA.ORG_PN=LPCM
http-get:
:audio/mp4:DLNA.ORG_PN=HEAACv2_L2_320
http-get:
:audio/vnd.dlna.adts:DLNA.ORG_PN=HEAACv2_L2_320
http-get:
:audio/x-ms-wma:DLNA.ORG_PN=WMABASE
http-get:
:audio/x-ms-wma:DLNA.ORG_PN=WMALSL
http-get::audio/L16;rate=44100;channels=2:
http-get::audio/L16;rate=48000;channels=2:
http-get::audio/mpeg:
http-get::audio/mp4:
http-get::audio/m4a:
http-get::audio/x-m4a:
http-get::audio/aac:
http-get::audio/wave:
http-get::audio/wav:
http-get::audio/x-wav:
http-get::audio/aiff:
http-get::audio/x-aiff:
http-get::audio/flac:
http-get::audio/x-flac:
http-get::audio/ation/ogg:
http-get::audio/ogg:
http-get::audio/vorbis:
http-get::audio/x-vorbis:
http-get::audio/dff:
http-get::audio/x-dff:
http-get::audio/dsf:
http-get::audio/x-dsf:
http-get::audio/:*
DLNA 1.5: Yes
Gapless playback: Yes
Missing events workaround: No
Can play native DSD: Yes
14 virtual formats:
0 physical formats
CurrentTransportState: TRANSITIONING
NrTracks: 0
MediaDuration: 0:00:00
CurrentURI:
CurrentURIMetadata: NOT_IMPLEMENTED
nextURI:
PlayMedium: NONE
<?xml version="1.0"?> 1 0 TransportState string STOPPED PAUSED_PLAYBACK PLAYING TRANSITIONING STOPPED TransportStatus string OK PlaybackStorageMedium string NONE RecordStorageMedium string NOT_IMPLEMENTED PossiblePlaybackStorageMedia string NETWORK PossibleRecordStorageMedia string NOT_IMPLEMENTED CurrentPlayMode string NORMAL NORMAL TransportPlaySpeed string 1 1 RecordMediumWriteStatus string NOT_IMPLEMENTED CurrentRecordQualityMode string NOT_IMPLEMENTED PossibleRecordQualityModes string NOT_IMPLEMENTED NumberOfTracks ui4 0 CurrentTrack ui4 0 1 CurrentTrackDuration string CurrentMediaDuration string CurrentTrackMetaData string CurrentTrackURI string AVTransportURI string AVTransportURIMetaData string NextAVTransportURI string NextAVTransportURIMetaData string RelativeTimePosition string AbsoluteTimePosition string RelativeCounterPosition i4 AbsoluteCounterPosition i4 CurrentTransportActions string LastChange string A_ARG_TYPE_SeekMode string TRACK_NR REL_TIME ABS_TIME A_ARG_TYPE_SeekTarget string A_ARG_TYPE_InstanceID ui4 SetNextAVTransportURI InstanceID in A_ARG_TYPE_InstanceID NextURI in NextAVTransportURI NextURIMetaData in NextAVTransportURIMetaData SetAVTransportURI InstanceID in A_ARG_TYPE_InstanceID CurrentURI in AVTransportURI CurrentURIMetaData in AVTransportURIMetaData GetMediaInfo InstanceID in A_ARG_TYPE_InstanceID NrTracks out NumberOfTracks MediaDuration out CurrentMediaDuration CurrentURI out AVTransportURI CurrentURIMetaData out AVTransportURIMetaData NextURI out NextAVTransportURI NextURIMetaData out NextAVTransportURIMetaData PlayMedium out PlaybackStorageMedium RecordMedium out RecordStorageMedium WriteStatus out RecordMediumWriteStatus GetTransportInfo InstanceID in A_ARG_TYPE_InstanceID CurrentTransportState out TransportState CurrentTransportStatus out TransportStatus CurrentSpeed out TransportPlaySpeed GetPositionInfo InstanceID in A_ARG_TYPE_InstanceID Track out CurrentTrack TrackDuration out CurrentTrackDuration TrackMetaData out CurrentTrackMetaData TrackURI out CurrentTrackURI RelTime out RelativeTimePosition AbsTime out AbsoluteTimePosition RelCount out RelativeCounterPosition AbsCount out AbsoluteCounterPosition GetDeviceCapabilities InstanceID in A_ARG_TYPE_InstanceID PlayMedia out PossiblePlaybackStorageMedia RecMedia out PossibleRecordStorageMedia RecQualityModes out PossibleRecordQualityModes GetTransportSettings InstanceID in A_ARG_TYPE_InstanceID PlayMode out CurrentPlayMode RecQualityMode out CurrentRecordQualityMode Stop InstanceID in A_ARG_TYPE_InstanceID Play InstanceID in A_ARG_TYPE_InstanceID Speed in TransportPlaySpeed Pause InstanceID in A_ARG_TYPE_InstanceID Seek InstanceID in A_ARG_TYPE_InstanceID Unit in A_ARG_TYPE_SeekMode Target in A_ARG_TYPE_SeekTarget Next InstanceID in A_ARG_TYPE_InstanceID Previous InstanceID in A_ARG_TYPE_InstanceID SetPlayMode InstanceID in A_ARG_TYPE_InstanceID NewPlayMode in CurrentPlayMode GetCurrentTransportActions InstanceID in A_ARG_TYPE_InstanceID Actions out CurrentTransportActions
<?xml version="1.0"?> 1 0 urn:schemas-upnp-org:device:MediaRenderer:1 851N Cambridge Audio http://www.cambridgeaudio.com/ 851N 2503 uuid:07063e00-329a-4fe8-b67e-ec79480a0346 000d958b image/png 48 48 8 /07063e00-329a-4fe8-b67e-ec79480a0346/CA-roundal-48x48.png image/jpeg 48 48 24 /07063e00-329a-4fe8-b67e-ec79480a0346/CA-roundal-48x48.jpg image/png 120 120 8 /07063e00-329a-4fe8-b67e-ec79480a0346/CA-roundal-120x120.png image/jpeg 120 120 24 /07063e00-329a-4fe8-b67e-ec79480a0346/CA-roundal-120x120.jpg urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /07063e00-329a-4fe8-b67e-ec79480a0346/RenderingControl/RenderingControl1.xml /07063e00-329a-4fe8-b67e-ec79480a0346/RenderingControl/invoke /07063e00-329a-4fe8-b67e-ec79480a0346/RenderingControl/event urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /07063e00-329a-4fe8-b67e-ec79480a0346/ConnectionManager/ConnectionManager1.xml /07063e00-329a-4fe8-b67e-ec79480a0346/ConnectionManager/invoke /07063e00-329a-4fe8-b67e-ec79480a0346/ConnectionManager/event urn:schemas-upnp-org:service:ContentDirectory:1 urn:upnp-org:serviceId:ContentDirectory /07063e00-329a-4fe8-b67e-ec79480a0346/ContentDirectory/ContentDirectory1.xml /07063e00-329a-4fe8-b67e-ec79480a0346/ContentDirectory/invoke /07063e00-329a-4fe8-b67e-ec79480a0346/ContentDirectory/event urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /07063e00-329a-4fe8-b67e-ec79480a0346/AVTransport/AVTransport1.xml /07063e00-329a-4fe8-b67e-ec79480a0346/AVTransport/invoke /07063e00-329a-4fe8-b67e-ec79480a0346/AVTransport/event urn:UuVol-com:service:UuVolControl:5 urn:UuVol-com:serviceId:UuVolControl /07063e00-329a-4fe8-b67e-ec79480a0346/RecivaRadio/RecivaRadio.xml /07063e00-329a-4fe8-b67e-ec79480a0346/RecivaRadio/invoke /07063e00-329a-4fe8-b67e-ec79480a0346/RecivaRadio/event urn:UuVol-com:service:PlaylistExtension:1 urn:UuVol-com:serviceId:PlaylistExtension /07063e00-329a-4fe8-b67e-ec79480a0346/UuPlaylist/Playlist.xml /07063e00-329a-4fe8-b67e-ec79480a0346/UuPlaylist/invoke /07063e00-329a-4fe8-b67e-ec79480a0346/UuPlaylist/event urn:UuVol-com:service:UuVolSimpleRemote:1 urn:UuVol-com:serviceId:UuVolSimpleRemote /07063e00-329a-4fe8-b67e-ec79480a0346/RecivaSimpleRemote/RecivaSimpleRemote.xml /07063e00-329a-4fe8-b67e-ec79480a0346/RecivaSimpleRemote/invoke /07063e00-329a-4fe8-b67e-ec79480a0346/RecivaSimpleRemote/event urn:UuVol-com:service:StreamMagic6:1 urn:UuVol-com:serviceId:StreamMagic6 /07063e00-329a-4fe8-b67e-ec79480a0346/StreamMagic6/StreamMagic6.xml /07063e00-329a-4fe8-b67e-ec79480a0346/StreamMagic6/invoke /07063e00-329a-4fe8-b67e-ec79480a0346/StreamMagic6/event urn:UuVol-com:service:SMSearch:1 urn:UuVol-com:serviceId:SMSearch /07063e00-329a-4fe8-b67e-ec79480a0346/SMSearch/SMSearch.xml /07063e00-329a-4fe8-b67e-ec79480a0346/SMSearch/invoke /07063e00-329a-4fe8-b67e-ec79480a0346/SMSearch/event DMR-1.50 M-DMP-1.50
UPnP devices found : 1
Device #0: ID 0x0 851N UID: uuid:07063e00-329a-4fe8-b67e-ec79480a0346 Location: http://192.168.178.69:8050/07063e00-329a-4fe8-b67e-ec79480a0346/description.xml
Max. memory for audio buffers: 62464MB
Device #0: ID 0x32 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:16 UID: AppleHDAEngineOutput:1F,3,0,1,1:0
Hello @Apierre ,
Do you have Music opened on your Mac at the same time as Studio?
Im guessing this is happeneing when streaming with Tidal? I had the same issue and solved by changing the settings for Tidal “limit streaming quality to” option which was previously at MQA and reducing it to high. Restarted application and AMP and it worked
