Stuck on synching library full progress bar
Greetings!
MacOS 12.6.8 (Monterey) with Audirvana 3.5.50
Recently, I noticed that when Audirvana syncs the library, the progress bar on the top of the screen will stay there, even when the bar is completely blue (100%)
I have to close and reopen Audirvana, then the sync progress bar goes away.
That is the only way I can sync again if I make any changes.
It never used to behave this way, and I can’t think of any changes I made.
I ran all 3 library maintenances, and nothing helps.
Any suggestions?
