Happened at 5 seconds then 14 seconds…
Audirvana Studio 1.10.0 (11000)
macOS Version 12.2 (Build 21D5039d) with 20GB physical RAM
Connected account of : Me
Effects plugins ACTIVE in offline mode with legacy macOS API
AU plugin #0: Music Effect - FabFilter Pro-Q 3 ()
AU plugin #1: None
AU plugin #2: None
AU plugin #3: None
Bandwidth at 0dB = 98.0165%
Phase = 66%
Sync list: 2 folders
AUTO: /Volumes/DISCO 1/MUSIC 1
AUTO: /Volumes/DISCO 2/MUSIC 2
Library database path: /Users/xxx/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 49553
Max. memory for audio buffers: 15340MB
WYRED 4 SOUND 32BIT 384KHZ DSD INTERFACE
Model UID:32bit 384kHz DSD Interface:27F7:1301
UID:AppleUSBAudioEngine:Wyred 4 Sound:32bit 384kHz DSD Interface:413-001:2
Device: 2ch Non-mixable linear PCM Interleaved 32bits little endian Signed Integer, 8 bytes per frame 48kHz
Active Sample Rate: 48kHz
Hog Mode is on
ID 0x47 32bit 384kHz DSD Interface
Manufacturer: Wyred 4 Sound
Model Name: Wyred 4 Sound 32bit 384kHz DSD Interface
Model UID: 32bit 384kHz DSD Interface:27F7:1301
UID: AppleUSBAudioEngine:Wyred 4 Sound:32bit 384kHz DSD Interface:413-001:2
Stream ID 0x48 2 channels starting at 1
16 virtual formats:
16 physical formats
Device #0: ID 0x47 32bit 384kHz DSD Interface Manufacturer: Wyred 4 Sound Model UID: 32bit 384kHz DSD Interface:27F7:1301 UID: AppleUSBAudioEngine:Wyred 4 Sound:32bit 384kHz DSD Interface:413-001:2 Model Name: Wyred 4 Sound 32bit 384kHz DSD Interface
Device #1: ID 0x51 Mac mini Speakers Manufacturer: Apple Inc. Model UID: Speaker UID: BuiltInSpeakerDevice Model Name: Apple Inc. Mac mini Speakers
