This is happening with every song. I has been a while since updating and all was working flawlessly with version 1.2? It continues to stream and show it playing, but no sound. If I do a complete stop and try the next track, the same thing, cuts out at 43 seconds. This is happening with Qobuz and now tried Tidal and it cuts out as well at the same 43 second time spot.
All settings the same, except I was a 3700 on allocated memory and tried the current one in the debug around 2000. I also tried the other direction going to 7000.
I also tried disabling the VST plugin that I have always used previously and it still cuts out at the same time.
Turning off upsampling does not fix the issue either. It still cuts out at 43 seconds.
As I am currently dead in the water and not able to listen to music.
Any help would be greatly appreciated,
Thx
Debug info below:
Audirvana Studio 2.2.2 (20202)
macOS 10.15.7 with 24GB physical RAM
Connected account of : Dan Bezak
AU plugin #0: Effect - Home Audio Fidelity Hifi_Aid ()
AU plugin #1: None
AU plugin #2: None
AU plugin #3: None
SoX to DSD256 with filter type B 7th order
Bandwidth at 0dB = 84.1012%
Phase = 71%
AUTO: /Users/dannybezak/Documents/Music
Library database path: /Users/dannybezak/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 60853
Max. memory for audio buffers: 1946MB
Local Audio Engine: CoreAudio
Exclusive access: ON
Integer mode: OFF
Use max I/O buffer size: OFF
CA CA DACMAGIC 200M 2.0
Model UID:CA DacMagic 200M 2.0:22E8:DAC2
UID:AppleUSBAudioEngine:CA:CA DacMagic 200M 2.0:14200000:1
Device: 2ch Mixable linear PCM Interleaved 32bits little endian Signed Float, 8 bytes per frame 705.6kHz
Active Sample Rate: 705.6kHz
Hog Mode is on
Selected device:CA DacMagic 200M 2.0
Manufacturer: CA
Model name: CA DacMagic 200M 2.0
Model UID: CA DacMagic 200M 2.0:22E8:DAC2
UID: AppleUSBAudioEngine:CA:CA DacMagic 200M 2.0:14200000:1
USB Vendor ID: 0x22e8
USB Product ID: 0xdac2
ID 0x52
Audio buffer frame size : 212 to 4096 frames
Stream ID 0x53 2 channels starting at 1
30 virtual formats:
40 physical formats
2 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 768kHz
Local devices found : 3
Device #0: ID 0x43 Built-in Output
Model UID: AppleHDA:7
Device #1: ID 0x52 CA DacMagic 200M 2.0
Manufacturer: CA
Device #2: ID 0x32 eqMac2
Manufacturer: Bitgapp
Model UID: com_bitgapp_eqMac2Driver:eqMac2
UID: EQMAC2.1_DRIVER_ENGINE
Model name: Bitgapp eqMac2
