The sound sounds great and clearer than Audirvana 3.5.
Analysing audio files does not progress and crashes after a few minutes !!!
User Interface is nice, sometimes confusing : for example, after a search, mixing results from local files and from Qobuz gives a lot of results and you end up not seeing your local files. It should be possible to select search results from local files / qobuz / others sources or a combination…
HD radio plays very well, but pause button is not effective.
As in Audirvana 3.5 browsing by directories is not available. For me this feature is really crucial, it is available in all other audio softwares that I have used: Foobar, Mediamonkey, Naim, mConnect… and it’s a pity that I have to use a different software to manage my audio files directory structure
As in Audirvana 3.5 album booklets do not display very clearly, as compared to a direct view of the pdf
