Studio has the existing ability to have a vertical split screen which opens when you select the Edit Playlist Button.
It would be good to also have the ability to apply a Horizontal Split therefore giving you 4 panes instead of 2. The particular zone could be higlighted to then select from the Edit Playlist Button at the top of the screen or any of the Left Side Options under the Headings from My Music, Qobuz/Tidal, Local, Radios or Podcasts.
I have attached a mashup photo…
