Studio shuts down after playing just a few tracks from qobuz. I have the same result whether playing standard bitrates or up-sampled. I have also uninstalled studio and reinstalled with the same outcome
Current version: 1.6.4 (10604)
r8brain with 2x upsampling
AUTO: D:
Library database path: C:\Users\darre\AppData\Local\Audirvana\Audirvana\AudirvanaDatabase.sqlite
Listening on 192.168.1.122 on port 60962
Max. memory for audio buffers: 14502MB
Speakers (DENAFRIPS USB DAC)
Model UID:TUSBAUDIO_ENUM\VID_152A&PID_86EF&REV_0303&KS
UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{f3444af4-d293-4e15-8d5b-1be70cc7b47a}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Manufacturer: DENAFRIPS Co. Ltd.
Model Name: Unknown manufacturer
Model UID: TUSBAUDIO_ENUM\VID_152A&PID_86EF&REV_0303&KS
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{f3444af4-d293-4e15-8d5b-1be70cc7b47a}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Kernel Streaming capable
12 available sample rates up to 1536000Hz
1411200
1536000
Simple stereo device: No
2 ch Integer PCM 32bit little endian 1411.2kHz
2 ch Integer PCM 32bit little endian 1536kHz
2 ch Integer PCM 24bit little endian 352.8kHz
2 ch Integer PCM 24bit little endian 384kHz
2 ch Integer PCM 24bit little endian 705.6kHz
2 ch Integer PCM 24bit little endian 768kHz
2 ch Integer PCM 24bit little endian 1411.2kHz
2 ch Integer PCM 24bit little endian 1536kHz
2 ch Integer PCM 16bit little endian 1411.2kHz
2 ch Integer PCM 16bit little endian 1536kHz
Local devices found : 3
Device #0: SAMSUNG (NVIDIA High Definition Audio) Manufacturer: NVIDIA Model UID: HDAUDIO\FUNC_01&VEN_10DE&DEV_0051&SUBSYS_104385E7&REV_1001 UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{3827403d-5b6b-42b9-9902-702042ddb021}#{e6327cad-dcec-4949-ae8a-991e976a79d2} Model Name: Unknown manufacturer
Device #1: Digital Audio (S/PDIF) (High Definition Audio Device) Manufacturer: Microsoft Model UID: HDAUDIO\FUNC_01&VEN_10EC&DEV_1168&SUBSYS_10438723&REV_1001 UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{33e0a424-5f03-4159-acec-12caaa890eca}#{e6327cad-dcec-4949-ae8a-991e976a79d2} Model Name: Unknown manufacturer
Device #2: Speakers (DENAFRIPS USB DAC) Manufacturer: DENAFRIPS Co. Ltd. Model UID: TUSBAUDIO_ENUM\VID_152A&PID_86EF&REV_0303&KS UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{f3444af4-d293-4e15-8d5b-1be70cc7b47a}#{e6327cad-dcec-4949-ae8a-991e976a79d2} Model Name: Unknown manufacturer
UPnP devices found : 2
Device #0[TV] Samsung 6 Series (40) UID: uuid:04f53da5-326f-4534-a91e-8bd24721d1de Location: http://192.168.1.78:9197/dmr
Device #1RX-V781 D85280 UID: uuid:9ab0c000-f668-11de-9976-00a0ded85280 Location: http://192.168.1.79:49154/MediaRenderer/desc.xml
