Hi there!..Just started with Studio today ,I have used Audirvana before. Wanted to see how Studio performed on wireless network connection. Not having much success. Plays back native files without artwork displayed.Playback stops mid point on tracks and stays that way. It will not upsample to DSD ,just very low level audio under white/pink type noise.
Here is debug info.
Thank DD
Audirvana Studio 2.2.3 (20203)
macOS 10.15.7 with 16GB physical RAM
Connected account of : Dave Davies
No plugin active
Bandwidth at 0dB = 99.5%
Phase = 66%
AUTO: /Volumes/HD LIBRARY/
Library database path: /Users/davedavies/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 49901
Active method: UPnP
Preferred device: [UPnP] Music room Model UID:AURALIC ALTAIR_G1 UID:uuid:lightningRender-bc-34-00-a0-4a-c9
Selected device:Music room
Manufacturer: AURALIC
Model name: ALTAIR_G1
Model UID: AURALIC ALTAIR_G1
UID: uuid:lightningRender-bc-34-00-a0-4a-c9
UPnP device at http://192.168.1.234:52874/lightningRender-bc-34-00-a0-4a-c9/Upnp/device.xml
ID 0x0
Volume control: Yes
UPnP set capabilities
Maximum PCM frequency set: 384000Hz
Maximum PCM bitdepth set: 24
Not native DSD capable
Avoid RAW PCM streams: No
http-get::audio/x-flac:
http-get::audio/wav:
http-get::audio/wave:
http-get::audio/x-wav:
http-get::audio/mpeg:
http-get::audio/x-mpeg:
http-get::audio/mp1:
http-get::audio/aiff:
http-get::audio/x-aiff:
http-get::audio/x-m4a:
http-get::audio/x-ms-wma:
rtsp-rtp-udp::audio/x-ms-wma:
http-get::audio/x-scpls:
http-get::audio/x-mpegurl:
http-get::audio/x-ms-asf:
http-get::audio/x-ms-wax:
http-get::audio/x-ms-wvx:
http-get::text/xml:
http-get::audio/aac:
http-get::audio/aacp:
http-get::audio/mp4:
http-get::audio/ogg:
http-get::audio/x-ogg:
http-get::application/ogg:
http-get::video/mpeg:
http-get::video/mp4:
http-get::video/quicktime:
http-get::video/webm:
http-get::video/x-ms-wmv:
http-get::video/x-ms-asf:
http-get::video/x-msvideo:
http-get::video/x-ms-wax:
http-get::video/x-ms-wvx:
http-get::video/x-m4v:
http-get::video/x-matroska:
http-get::application/octet-stream:
DLNA 1.5: No
Native Gapless playback: Yes
Universal Gapless playback active: Yes
Missing events workaround: No
Can play native DSD: No
Volume Control: dB
16 virtual formats:
0 physical formats
CurrentTransportState: TRANSITIONING
CurrentSpeed: 0
NrTracks: 1
MediaDuration: 0:00:00
CurrentURI: http://192.168.1.244:49153/audirvana/gaplessAudio_41.wav
CurrentURIMetadata:
dc:titleAudirvana gapless playback</dc:title>
nextURI:
nextURIMetadata:
PlayMedium: NETWORK
Current transport actions:
<?xml version="1.0"?> 1 1 urn:schemas-upnp-org:device:MediaRenderer:1 Music room QPlay:2 AURALIC ALTAIR_G1 uuid:lightningRender-bc-34-00-a0-4a-c9 urn:openhome-org:service:SubscriptionLongPoll:1 urn:openhome-org:serviceId:SubscriptionLongPoll /lightningRender-bc-34-00-a0-4a-c9/Upnp/openhome.org-SubscriptionLongPoll-1/service.xml /lightningRender-bc-34-00-a0-4a-c9/openhome.org-SubscriptionLongPoll-1/control urn:av-openhome-org:service:Product:1 urn:av-openhome-org:serviceId:Product /lightningRender-bc-34-00-a0-4a-c9/Upnp/av.openhome.org-Product-1/service.xml /lightningRender-bc-34-00-a0-4a-c9/av.openhome.org-Product-1/control /lightningRender-bc-34-00-a0-4a-c9/av.openhome.org-Product-1/event urn:av-openhome-org:service:Playlist:1 urn:av-openhome-org:serviceId:Playlist /lightningRender-bc-34-00-a0-4a-c9/Upnp/av.openhome.org-Playlist-1/service.xml /lightningRender-bc-34-00-a0-4a-c9/av.openhome.org-Playlist-1/control /lightningRender-bc-34-00-a0-4a-c9/av.openhome.org-Playlist-1/event urn:av-openhome-org:service:Bluetooth:1 urn:av-openhome-org:serviceId:Bluetooth /lightningRender-bc-34-00-a0-4a-c9/Upnp/av.openhome.org-Bluetooth-1/service.xml /lightningRender-bc-34-00-a0-4a-c9/av.openhome.org-Bluetooth-1/control /lightningRender-bc-34-00-a0-4a-c9/av.openhome.org-Bluetooth-1/event urn:av-openhome-org:service:Airplay:1 urn:av-openhome-org:serviceId:Airplay /lightningRender-bc-34-00-a0-4a-c9/Upnp/av.openhome.org-Airplay-1/service.xml /lightningRender-bc-34-00-a0-4a-c9/av.openhome.org-Airplay-1/control /lightningRender-bc-34-00-a0-4a-c9/av.openhome.org-Airplay-1/event urn:av-openhome-org:service:Spotify:1 urn:av-openhome-org:serviceId:Spotify /lightningRender-bc-34-00-a0-4a-c9/Upnp/av.openhome.org-Spotify-1/service.xml /lightningRender-bc-34-00-a0-4a-c9/av.openhome.org-Spotify-1/control /lightningRender-bc-34-00-a0-4a-c9/av.openhome.org-Spotify-1/event urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /lightningRender-bc-34-00-a0-4a-c9/Upnp/upnp.org-ConnectionManager-1/service.xml /lightningRender-bc-34-00-a0-4a-c9/upnp.org-ConnectionManager-1/control /lightningRender-bc-34-00-a0-4a-c9/upnp.org-ConnectionManager-1/event urn:av-openhome-org:service:TidalConnect:1 urn:av-openhome-org:serviceId:TidalConnect /lightningRender-bc-34-00-a0-4a-c9/Upnp/av.openhome.org-TidalConnect-1/service.xml /lightningRender-bc-34-00-a0-4a-c9/av.openhome.org-TidalConnect-1/control /lightningRender-bc-34-00-a0-4a-c9/av.openhome.org-TidalConnect-1/event urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /lightningRender-bc-34-00-a0-4a-c9/Upnp/upnp.org-RenderingControl-1/service.xml /lightningRender-bc-34-00-a0-4a-c9/upnp.org-RenderingControl-1/control /lightningRender-bc-34-00-a0-4a-c9/upnp.org-RenderingControl-1/event urn:av-openhome-org:service:InternetRadio:1 urn:av-openhome-org:serviceId:InternetRadio /lightningRender-bc-34-00-a0-4a-c9/Upnp/av.openhome.org-InternetRadio-1/service.xml /lightningRender-bc-34-00-a0-4a-c9/av.openhome.org-InternetRadio-1/control /lightningRender-bc-34-00-a0-4a-c9/av.openhome.org-InternetRadio-1/event urn:av-openhome-org:service:Time:1 urn:av-openhome-org:serviceId:Time /lightningRender-bc-34-00-a0-4a-c9/Upnp/av.openhome.org-Time-1/service.xml /lightningRender-bc-34-00-a0-4a-c9/av.openhome.org-Time-1/control /lightningRender-bc-34-00-a0-4a-c9/av.openhome.org-Time-1/event urn:av-openhome-org:service:Info:1 urn:av-openhome-org:serviceId:Info /lightningRender-bc-34-00-a0-4a-c9/Upnp/av.openhome.org-Info-1/service.xml /lightningRender-bc-34-00-a0-4a-c9/av.openhome.org-Info-1/control /lightningRender-bc-34-00-a0-4a-c9/av.openhome.org-Info-1/event urn:av-openhome-org:service:GroupConfig:1 urn:av-openhome-org:serviceId:GroupConfig /lightningRender-bc-34-00-a0-4a-c9/Upnp/av.openhome.org-GroupConfig-1/service.xml /lightningRender-bc-34-00-a0-4a-c9/av.openhome.org-GroupConfig-1/control /lightningRender-bc-34-00-a0-4a-c9/av.openhome.org-GroupConfig-1/event urn:av-openhome-org:service:MusicStation:1 urn:av-openhome-org:serviceId:MusicStation /lightningRender-bc-34-00-a0-4a-c9/Upnp/av.openhome.org-MusicStation-1/service.xml /lightningRender-bc-34-00-a0-4a-c9/av.openhome.org-MusicStation-1/control /lightningRender-bc-34-00-a0-4a-c9/av.openhome.org-MusicStation-1/event urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /lightningRender-bc-34-00-a0-4a-c9/Upnp/upnp.org-AVTransport-1/service.xml /lightningRender-bc-34-00-a0-4a-c9/upnp.org-AVTransport-1/control /lightningRender-bc-34-00-a0-4a-c9/upnp.org-AVTransport-1/event urn:schemas-tencent-com:service:QPlay:1 urn:tencent-com:serviceId:QPlay /lightningRender-bc-34-00-a0-4a-c9/Upnp/tencent.com-QPlay-1/service.xml /lightningRender-bc-34-00-a0-4a-c9/tencent.com-QPlay-1/control urn:av-openhome-org:service:Receiver:1 urn:av-openhome-org:serviceId:Receiver /lightningRender-bc-34-00-a0-4a-c9/Upnp/av.openhome.org-Receiver-1/service.xml /lightningRender-bc-34-00-a0-4a-c9/av.openhome.org-Receiver-1/control /lightningRender-bc-34-00-a0-4a-c9/av.openhome.org-Receiver-1/event urn:av-openhome-org:service:Credentials:1 urn:av-openhome-org:serviceId:Credentials /lightningRender-bc-34-00-a0-4a-c9/Upnp/av.openhome.org-Credentials-1/service.xml /lightningRender-bc-34-00-a0-4a-c9/av.openhome.org-Credentials-1/control /lightningRender-bc-34-00-a0-4a-c9/av.openhome.org-Credentials-1/event urn:av-openhome-org:service:Roon:1 urn:av-openhome-org:serviceId:Roon /lightningRender-bc-34-00-a0-4a-c9/Upnp/av.openhome.org-Roon-1/service.xml /lightningRender-bc-34-00-a0-4a-c9/av.openhome.org-Roon-1/control /lightningRender-bc-34-00-a0-4a-c9/av.openhome.org-Roon-1/event urn:av-openhome-org:service:Volume:1 urn:av-openhome-org:serviceId:Volume /lightningRender-bc-34-00-a0-4a-c9/Upnp/av.openhome.org-Volume-1/service.xml /lightningRender-bc-34-00-a0-4a-c9/av.openhome.org-Volume-1/control /lightningRender-bc-34-00-a0-4a-c9/av.openhome.org-Volume-1/event urn:av-openhome-org:service:MessageCenter:1 urn:av-openhome-org:serviceId:MessageCenter /lightningRender-bc-34-00-a0-4a-c9/Upnp/av.openhome.org-MessageCenter-1/service.xml /lightningRender-bc-34-00-a0-4a-c9/av.openhome.org-MessageCenter-1/control /lightningRender-bc-34-00-a0-4a-c9/av.openhome.org-MessageCenter-1/event urn:av-openhome-org:service:HardwareConfig:1 urn:av-openhome-org:serviceId:HardwareConfig /lightningRender-bc-34-00-a0-4a-c9/Upnp/av.openhome.org-HardwareConfig-1/service.xml /lightningRender-bc-34-00-a0-4a-c9/av.openhome.org-HardwareConfig-1/control /lightningRender-bc-34-00-a0-4a-c9/av.openhome.org-HardwareConfig-1/event urn:av-openhome-org:service:WebProcessorConfig:1 urn:av-openhome-org:serviceId:WebProcessorConfig /lightningRender-bc-34-00-a0-4a-c9/Upnp/av.openhome.org-WebProcessorConfig-1/service.xml /lightningRender-bc-34-00-a0-4a-c9/av.openhome.org-WebProcessorConfig-1/control /lightningRender-bc-34-00-a0-4a-c9/av.openhome.org-WebProcessorConfig-1/event urn:av-openhome-org:service:WebRendererConfig:1 urn:av-openhome-org:serviceId:WebRendererConfig /lightningRender-bc-34-00-a0-4a-c9/Upnp/av.openhome.org-WebRendererConfig-1/service.xml /lightningRender-bc-34-00-a0-4a-c9/av.openhome.org-WebRendererConfig-1/control /lightningRender-bc-34-00-a0-4a-c9/av.openhome.org-WebRendererConfig-1/event urn:av-openhome-org:service:WebDeviceConfig:1 urn:av-openhome-org:serviceId:WebDeviceConfig /lightningRender-bc-34-00-a0-4a-c9/Upnp/av.openhome.org-WebDeviceConfig-1/service.xml /lightningRender-bc-34-00-a0-4a-c9/av.openhome.org-WebDeviceConfig-1/control /lightningRender-bc-34-00-a0-4a-c9/av.openhome.org-WebDeviceConfig-1/event urn:av-openhome-org:service:WebDACConfig:1 urn:av-openhome-org:serviceId:WebDACConfig /lightningRender-bc-34-00-a0-4a-c9/Upnp/av.openhome.org-WebDACConfig-1/service.xml /lightningRender-bc-34-00-a0-4a-c9/av.openhome.org-WebDACConfig-1/control /lightningRender-bc-34-00-a0-4a-c9/av.openhome.org-WebDACConfig-1/event urn:av-openhome-org:service:RenderingInfo:1 urn:av-openhome-org:serviceId:RenderingInfo /lightningRender-bc-34-00-a0-4a-c9/Upnp/av.openhome.org-RenderingInfo-1/service.xml /lightningRender-bc-34-00-a0-4a-c9/av.openhome.org-RenderingInfo-1/control /lightningRender-bc-34-00-a0-4a-c9/av.openhome.org-RenderingInfo-1/eventCurrent device RootDevice description:
<?xml version="1.0"?> 1 1 urn:schemas-upnp-org:device:MediaRenderer:1 Music room QPlay:2 AURALIC ALTAIR_G1 uuid:lightningRender-bc-34-00-a0-4a-c9 urn:openhome-org:service:SubscriptionLongPoll:1 urn:openhome-org:serviceId:SubscriptionLongPoll /lightningRender-bc-34-00-a0-4a-c9/Upnp/openhome.org-SubscriptionLongPoll-1/service.xml /lightningRender-bc-34-00-a0-4a-c9/openhome.org-SubscriptionLongPoll-1/control urn:av-openhome-org:service:Product:1 urn:av-openhome-org:serviceId:Product /lightningRender-bc-34-00-a0-4a-c9/Upnp/av.openhome.org-Product-1/service.xml /lightningRender-bc-34-00-a0-4a-c9/av.openhome.org-Product-1/control /lightningRender-bc-34-00-a0-4a-c9/av.openhome.org-Product-1/event urn:av-openhome-org:service:Playlist:1 urn:av-openhome-org:serviceId:Playlist /lightningRender-bc-34-00-a0-4a-c9/Upnp/av.openhome.org-Playlist-1/service.xml /lightningRender-bc-34-00-a0-4a-c9/av.openhome.org-Playlist-1/control /lightningRender-bc-34-00-a0-4a-c9/av.openhome.org-Playlist-1/event urn:av-openhome-org:service:Bluetooth:1 urn:av-openhome-org:serviceId:Bluetooth /lightningRender-bc-34-00-a0-4a-c9/Upnp/av.openhome.org-Bluetooth-1/service.xml /lightningRender-bc-34-00-a0-4a-c9/av.openhome.org-Bluetooth-1/control /lightningRender-bc-34-00-a0-4a-c9/av.openhome.org-Bluetooth-1/event urn:av-openhome-org:service:Airplay:1 urn:av-openhome-org:serviceId:Airplay /lightningRender-bc-34-00-a0-4a-c9/Upnp/av.openhome.org-Airplay-1/service.xml /lightningRender-bc-34-00-a0-4a-c9/av.openhome.org-Airplay-1/control /lightningRender-bc-34-00-a0-4a-c9/av.openhome.org-Airplay-1/event urn:av-openhome-org:service:Spotify:1 urn:av-openhome-org:serviceId:Spotify /lightningRender-bc-34-00-a0-4a-c9/Upnp/av.openhome.org-Spotify-1/service.xml /lightningRender-bc-34-00-a0-4a-c9/av.openhome.org-Spotify-1/control /lightningRender-bc-34-00-a0-4a-c9/av.openhome.org-Spotify-1/event urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /lightningRender-bc-34-00-a0-4a-c9/Upnp/upnp.org-ConnectionManager-1/service.xml /lightningRender-bc-34-00-a0-4a-c9/upnp.org-ConnectionManager-1/control /lightningRender-bc-34-00-a0-4a-c9/upnp.org-ConnectionManager-1/event urn:av-openhome-org:service:TidalConnect:1 urn:av-openhome-org:serviceId:TidalConnect /lightningRender-bc-34-00-a0-4a-c9/Upnp/av.openhome.org-TidalConnect-1/service.xml /lightningRender-bc-34-00-a0-4a-c9/av.openhome.org-TidalConnect-1/control /lightningRender-bc-34-00-a0-4a-c9/av.openhome.org-TidalConnect-1/event urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /lightningRender-bc-34-00-a0-4a-c9/Upnp/upnp.org-RenderingControl-1/service.xml /lightningRender-bc-34-00-a0-4a-c9/upnp.org-RenderingControl-1/control /lightningRender-bc-34-00-a0-4a-c9/upnp.org-RenderingControl-1/event urn:av-openhome-org:service:InternetRadio:1 urn:av-openhome-org:serviceId:InternetRadio /lightningRender-bc-34-00-a0-4a-c9/Upnp/av.openhome.org-InternetRadio-1/service.xml /lightningRender-bc-34-00-a0-4a-c9/av.openhome.org-InternetRadio-1/control /lightningRender-bc-34-00-a0-4a-c9/av.openhome.org-InternetRadio-1/event urn:av-openhome-org:service:Time:1 urn:av-openhome-org:serviceId:Time /lightningRender-bc-34-00-a0-4a-c9/Upnp/av.openhome.org-Time-1/service.xml /lightningRender-bc-34-00-a0-4a-c9/av.openhome.org-Time-1/control /lightningRender-bc-34-00-a0-4a-c9/av.openhome.org-Time-1/event urn:av-openhome-org:service:Info:1 urn:av-openhome-org:serviceId:Info /lightningRender-bc-34-00-a0-4a-c9/Upnp/av.openhome.org-Info-1/service.xml /lightningRender-bc-34-00-a0-4a-c9/av.openhome.org-Info-1/control /lightningRender-bc-34-00-a0-4a-c9/av.openhome.org-Info-1/event urn:av-openhome-org:service:GroupConfig:1 urn:av-openhome-org:serviceId:GroupConfig /lightningRender-bc-34-00-a0-4a-c9/Upnp/av.openhome.org-GroupConfig-1/service.xml /lightningRender-bc-34-00-a0-4a-c9/av.openhome.org-GroupConfig-1/control /lightningRender-bc-34-00-a0-4a-c9/av.openhome.org-GroupConfig-1/event urn:av-openhome-org:service:MusicStation:1 urn:av-openhome-org:serviceId:MusicStation /lightningRender-bc-34-00-a0-4a-c9/Upnp/av.openhome.org-MusicStation-1/service.xml /lightningRender-bc-34-00-a0-4a-c9/av.openhome.org-MusicStation-1/control /lightningRender-bc-34-00-a0-4a-c9/av.openhome.org-MusicStation-1/event urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /lightningRender-bc-34-00-a0-4a-c9/Upnp/upnp.org-AVTransport-1/service.xml /lightningRender-bc-34-00-a0-4a-c9/upnp.org-AVTransport-1/control /lightningRender-bc-34-00-a0-4a-c9/upnp.org-AVTransport-1/event urn:schemas-tencent-com:service:QPlay:1 urn:tencent-com:serviceId:QPlay /lightningRender-bc-34-00-a0-4a-c9/Upnp/tencent.com-QPlay-1/service.xml /lightningRender-bc-34-00-a0-4a-c9/tencent.com-QPlay-1/control urn:av-openhome-org:service:Receiver:1 urn:av-openhome-org:serviceId:Receiver /lightningRender-bc-34-00-a0-4a-c9/Upnp/av.openhome.org-Receiver-1/service.xml /lightningRender-bc-34-00-a0-4a-c9/av.openhome.org-Receiver-1/control /lightningRender-bc-34-00-a0-4a-c9/av.openhome.org-Receiver-1/event urn:av-openhome-org:service:Credentials:1 urn:av-openhome-org:serviceId:Credentials /lightningRender-bc-34-00-a0-4a-c9/Upnp/av.openhome.org-Credentials-1/service.xml /lightningRender-bc-34-00-a0-4a-c9/av.openhome.org-Credentials-1/control /lightningRender-bc-34-00-a0-4a-c9/av.openhome.org-Credentials-1/event urn:av-openhome-org:service:Roon:1 urn:av-openhome-org:serviceId:Roon /lightningRender-bc-34-00-a0-4a-c9/Upnp/av.openhome.org-Roon-1/service.xml /lightningRender-bc-34-00-a0-4a-c9/av.openhome.org-Roon-1/control /lightningRender-bc-34-00-a0-4a-c9/av.openhome.org-Roon-1/event urn:av-openhome-org:service:Volume:1 urn:av-openhome-org:serviceId:Volume /lightningRender-bc-34-00-a0-4a-c9/Upnp/av.openhome.org-Volume-1/service.xml /lightningRender-bc-34-00-a0-4a-c9/av.openhome.org-Volume-1/control /lightningRender-bc-34-00-a0-4a-c9/av.openhome.org-Volume-1/event urn:av-openhome-org:service:MessageCenter:1 urn:av-openhome-org:serviceId:MessageCenter /lightningRender-bc-34-00-a0-4a-c9/Upnp/av.openhome.org-MessageCenter-1/service.xml /lightningRender-bc-34-00-a0-4a-c9/av.openhome.org-MessageCenter-1/control /lightningRender-bc-34-00-a0-4a-c9/av.openhome.org-MessageCenter-1/event urn:av-openhome-org:service:HardwareConfig:1 urn:av-openhome-org:serviceId:HardwareConfig /lightningRender-bc-34-00-a0-4a-c9/Upnp/av.openhome.org-HardwareConfig-1/service.xml /lightningRender-bc-34-00-a0-4a-c9/av.openhome.org-HardwareConfig-1/control /lightningRender-bc-34-00-a0-4a-c9/av.openhome.org-HardwareConfig-1/event urn:av-openhome-org:service:WebProcessorConfig:1 urn:av-openhome-org:serviceId:WebProcessorConfig /lightningRender-bc-34-00-a0-4a-c9/Upnp/av.openhome.org-WebProcessorConfig-1/service.xml /lightningRender-bc-34-00-a0-4a-c9/av.openhome.org-WebProcessorConfig-1/control /lightningRender-bc-34-00-a0-4a-c9/av.openhome.org-WebProcessorConfig-1/event urn:av-openhome-org:service:WebRendererConfig:1 urn:av-openhome-org:serviceId:WebRendererConfig /lightningRender-bc-34-00-a0-4a-c9/Upnp/av.openhome.org-WebRendererConfig-1/service.xml /lightningRender-bc-34-00-a0-4a-c9/av.openhome.org-WebRendererConfig-1/control /lightningRender-bc-34-00-a0-4a-c9/av.openhome.org-WebRendererConfig-1/event urn:av-openhome-org:service:WebDeviceConfig:1 urn:av-openhome-org:serviceId:WebDeviceConfig /lightningRender-bc-34-00-a0-4a-c9/Upnp/av.openhome.org-WebDeviceConfig-1/service.xml /lightningRender-bc-34-00-a0-4a-c9/av.openhome.org-WebDeviceConfig-1/control /lightningRender-bc-34-00-a0-4a-c9/av.openhome.org-WebDeviceConfig-1/event urn:av-openhome-org:service:WebDACConfig:1 urn:av-openhome-org:serviceId:WebDACConfig /lightningRender-bc-34-00-a0-4a-c9/Upnp/av.openhome.org-WebDACConfig-1/service.xml /lightningRender-bc-34-00-a0-4a-c9/av.openhome.org-WebDACConfig-1/control /lightningRender-bc-34-00-a0-4a-c9/av.openhome.org-WebDACConfig-1/event urn:av-openhome-org:service:RenderingInfo:1 urn:av-openhome-org:serviceId:RenderingInfo /lightningRender-bc-34-00-a0-4a-c9/Upnp/av.openhome.org-RenderingInfo-1/service.xml /lightningRender-bc-34-00-a0-4a-c9/av.openhome.org-RenderingInfo-1/control /lightningRender-bc-34-00-a0-4a-c9/av.openhome.org-RenderingInfo-1/eventUPnP devices found : 1
Device #0: ID 0x0 : Music room
Location: http://192.168.1.234:52874/lightningRender-bc-34-00-a0-4a-c9/Upnp/device.xml
Local Audio Engine: CoreAudio
Device #0: ID 0x30 Built-in Output
Model UID: AppleHDA:32
