Studio not loading tracks?
Hi Folks … any ideas on this one?
Occasionally tracks just wont play on Studio for me. I press play and although the curser moves through the track it stays at 0.00 and I have to restart my mac.
So its Studio I’m using on my Mac Mini which links via USB to a SMSL SU-9 MOA external DAC then via RCA to a Leak 130 Amplifier. Any suggestions would be appreciated, cheers.
This can have lots of reasons.
More information on your system is needed. Please copy Audirvana’s debug info in this thread.
In another thread I saw you use Audirvana Origin and Studio:
  • Does this happen only in Studio or in Origin too?
  • How is your music library connected to Studio and Origin (NAS or external USB hard drive etc)?
  • Do you have this problem with your local library or only with a streaming service like Qobuz or Tidal? In the latter case it can be a connection problem on your (local) network.
  • Does it always happen with the same files?
  • Do you have a stable connection between your Mac and your Music library.
etc. etc. etc.
Hi - thanks for replying, Debug info as follows.
It happens in both Studio and Origin.
My library is on an external hard drive connected to my Mac Mini via USB.
Only happens with my own library.
Happens with any file I play. Only a restart of my Mac sorts the issue,
Audirvana Origin 2.2.4 (20204)
macOS 10.15.7 with 8GB physical RAM
Connected account of : Ian Marshall
	AU plugin #1: None
	AU plugin #2: None
	AU plugin #3: None
SW volume control: ON
Sync list: 2 folders
AUTO: /Volumes/WD Sv/Google Drive/Music
Manual: /Volumes/WD Sv/Google Drive/Music/Sound of Movies (Pure DSD)
Library database path: /Users/ianmarshall/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 64631
Local Audio Engine: CoreAudio
Exclusive access: ON
Integer mode: ON
SMSL SMSL USB AUDIO
Model UID:SMSL USB AUDIO:152A:85DD
UID:AppleUSBAudioEngine:SMSL:SMSL USB AUDIO:14100000:1
Device: 2ch Non-mixable linear PCM Interleaved 32bits little endian Signed Integer, 8 bytes per frame 96kHz
Active Sample Rate: 96kHz
Hog Mode is on
Selected device:SMSL USB AUDIO
Manufacturer: SMSL
Model name: SMSL USB AUDIO
Model UID: SMSL USB AUDIO:152A:85DD
UID: AppleUSBAudioEngine:SMSL:SMSL USB AUDIO:14100000:1
USB Vendor ID: 0x152a
USB Product ID: 0x85dd
ID 0x3e
MQA Decoder device
Stream ID 0x3f 2 channels starting at 1
12 virtual formats:
16 physical formats
Local devices found : 3
Device #0: ID 0x33 Built-in Output
Model UID: AppleHDA:88
Device #1: ID 0x3a HDMI
UID: AppleHDAEngineOutputDP:1B,3,1,2:0:{D94D-050C-01010101}
Model name: Apple Inc. HDMI
Device #2: ID 0x3e SMSL USB AUDIO
Manufacturer: SMSL
Chromecast devices found : 1
Device #0: 55OLED805/12
Model name: TPM191E
maybe Google Drive is not allowing Audirvana or
Audirvana allowed with external hard drive in macos?
