Ok, thx for the advice.
My Set Up is as follows:
Old Dell laptop (Windows 10) connected to internet via WiFi, using Audirvãna for streaming Qobuz with UPnP to my Naim ND5 XS 2. ND5 XS 2 has two outputs: one DIN and one digital BNC. The first one I use for playing Qobuz over my Naim Nait1 with Spendor Cassic 4/5 speakers. The second one I use for playing to a Fiio BTA30 Pro that send the signal over bluetooth to my headphones (not ideal, but mainly for convenience so I can wander around…).
Problem occurred when using the second option. Very important is to know that although Audirvãna states that Firewall is enabled, it is NOT!
Debug Info:
Audirvana Studio 2.5.4 (20504)
Windows 10 (19045) with 8GB physical RAM
Connected account of : **********
Available network interfaces:
Reen120606-W6 ({0010b01c-3c78-4c44-9382-299c8c7d1cbf}) is private
Active profile types: all
Private profile:
Firewall: enabled
Inbound: blocked
Outbound: allowed
Notifications: enabled
Public profile:
Firewall: enabled
Inbound: blocked
Outbound: allowed
Network interface INBOUND traffic is BLOCKED: potential issue for Remote, UPnP, and Chromecast
SoX with 2x upsampling
Bandwidth at 0dB = 99.5%
Phase = 66%
Sync list: 2 folders
AUTO: C:\Users\frido\OneDrive\Muziek\CD rip
AUTO: C:\Users\frido\OneDrive\Muziek\Downloads
Library database path: C:\Users\frido\AppData\Local\Packages\Audirvana.Audirvana-4118-9684-d80dbb7827cd_q3nymrkmej12j\LocalCache\Local\Audirvana\Audirvana\AudirvanaDatabase.sqlite
Tracks with no MBID: 481
Listening on 192.168.1.209 on port 53739
Active method: UPnP
Preferred device: [UPnP] Naim ND5 XS 2 Model UID:Naim Audio ND5 XS 2 UID:uuid:6a736d54-bac1-4223-a5f6-3c2fa21f8496
Currently playing to UPnP device at 32 bits 192kHz
Selected device:Naim ND5 XS 2
Manufacturer: Naim Audio
Model name: ND5 XS 2
Model UID: Naim Audio ND5 XS 2
UID: uuid:6a736d54-bac1-4223-a5f6-3c2fa21f8496
UPnP device at http://192.168.1.55:42411/6a736d54-bac1-4223-a5f6-3c2fa21f8496.xml
2822400
5644800
11289600
22579200
Volume control: Yes
DSD capability: Raw DSD (msb)
UPnP set capabilities
Maximum PCM bitdepth set: 32
Maximum DSD rate set: DSD512
Avoid RAW PCM streams: No
http-get::text/xml:dlna.org_pn=didl_s
http-get::audio/vnd.dlna.adts:dlna.org_pn=heaacv2_l2_320
http-get::audio/x-ms-wma:dlna.org_pn=wmafull
http-get::audio/x-ms-wma:dlna.org_pn=wmabase
http-get::audio/3gpp:dlna.org_pn=heaacv2_l2_320
http-get::audio/mp4:dlna.org_pn=heaacv2_l2_320
http-get::audio/l16;rate=48000;channels=1:dlna.org_pn=lpcm
http-get::audio/l16;rate=48000;channels=2:dlna.org_pn=lpcm
http-get::audio/l16;rate=44100;channels=1:dlna.org_pn=lpcm
http-get::audio/l16;rate=44100;channels=2:dlna.org_pn=lpcm
http-get::audio/mpeg:dlna.org_pn=mp3
rtsp-rtp-udp::text/xml:dlna.org_pn=didl_s
rtsp-rtp-udp::audio/vnd.dlna.adts:dlna.org_pn=heaacv2_l2_320
rtsp-rtp-udp::audio/x-ms-wma:dlna.org_pn=wmafull
rtsp-rtp-udp::audio/x-ms-wma:dlna.org_pn=wmabase
rtsp-rtp-udp::audio/3gpp:dlna.org_pn=heaacv2_l2_320
rtsp-rtp-udp::audio/mp4:dlna.org_pn=heaacv2_l2_320
rtsp-rtp-udp::audio/l16;rate=48000;channels=1:dlna.org_pn=lpcm
rtsp-rtp-udp::audio/l16;rate=48000;channels=2:dlna.org_pn=lpcm
rtsp-rtp-udp::audio/l16;rate=44100;channels=1:dlna.org_pn=lpcm
rtsp-rtp-udp::audio/l16;rate=44100;channels=2:dlna.org_pn=lpcm
rtsp-rtp-udp::audio/mpeg:dlna.org_pn=mp3
http-get::audio/aac:
http-get::audio/x_pm_flac:
http-get::audio/x-flac:
http-get::application/ogg:
http-get::audio/aiff:
http-get::audio/x-wav:
http-get::audio/x-m4a:
http-get::text/xml:
http-get::audio/wave:
http-get::audio/vorbis:
http-get::audio/x-dsf:
http-get::audio/x-aiff:
http-get::audio/ogg:
http-get::audio/x-dff:
http-get::audio/wav:
http-get::audio/m4a:
http-get::audio/flac:
rtsp-rtp-udp::audio/aac:
rtsp-rtp-udp::audio/x_pm_flac:
rtsp-rtp-udp::audio/x-flac:
rtsp-rtp-udp::audio/aiff:
rtsp-rtp-udp::audio/x-wav:
rtsp-rtp-udp::audio/x-m4a:
rtsp-rtp-udp::audio/wave:
rtsp-rtp-udp::audio/vorbis:
rtsp-rtp-udp::audio/x-dsf:
rtsp-rtp-udp::audio/x-aiff:
rtsp-rtp-udp::audio/ogg:
rtsp-rtp-udp::audio/x-dff:
rtsp-rtp-udp::audio/wav:
rtsp-rtp-udp::audio/m4a:
rtsp-rtp-udp::audio/flac:
DLNA 1.5: Yes
Native Gapless playback: Yes
Missing events workaround: No
Can play native DSD: Yes
Volume Control: scalar
2 ch Integer PCM 16bit little endian 705.6kHz finite length
2 ch Integer PCM 24bit little endian 705.6kHz finite length
2 ch Integer PCM 32bit little endian 705.6kHz finite length
2 ch Integer PCM 16bit little endian 768kHz finite length
2 ch Integer PCM 24bit little endian 768kHz finite length
2 ch Integer PCM 32bit little endian 768kHz finite length
2 ch DSD 8bit little endian in 8bit chunk 22579.2kHz finite length
NrTracks: 1
MediaDuration: 0:06:22
CurrentURI: http://192.168.1.209:49152/audirvana/audio_f_51.wav
CurrentURIMetadata:
dc:titleMercy Street (Remaster 2012)</dc:title>
dc:creatorPeter Gabriel</dc:creator>
upnp:artistPeter Gabriel</upnp:artist>
upnp:genreRock</upnp:genre>
upnp:albumArtURIhttp://static.qobuz.com/images/covers/9b/b1/kjsz9jmqpb19b_600.jpg</upnp:albumArtURI>
upnp:albumSo (Remastered)</upnp:album>
upnp:originalTrackNumber5</upnp:originalTrackNumber>
nextURI: http://192.168.1.209:49152/audirvana/audio_f_53.wav
Your Song
Elton John
Elton John
Pop
http://static.qobuz.com/images/covers/30/01/0060253760130_600.jpg
Elton John
1
object.item.audioItem.musicTrack
PlayMedium: NETWORK
Current transport actions:
Play,Stop,Next,Seek
<?xml version="1.0"?>
1
0
QPlay:2
Naim ND5 XS 2
Naim Audio
http://www.naimaudio.com/
Naim streaming audio player
ND5 XS 2
20-015-0044
https://www.naimaudio.com/product/nd5-xs2
471370
image/png
120
120
24
/LibRygelRenderer-120x120x24.png
image/png
48
48
24
/LibRygelRenderer-48x48x24.png
image/png
32
32
24
/LibRygelRenderer-32x32x24.png
image/png
128
128
24
/LibRygelRenderer-128x128x24.png
image/png
240
240
24
/LibRygelRenderer-240x240x24.png
image/png
480
480
24
/LibRygelRenderer-480x480x24.png
image/png
600
600
24
/LibRygelRenderer-600x600x24.png
image/jpeg
120
120
24
/LibRygelRenderer-120x120x24.jpg
image/jpeg
48
48
24
/LibRygelRenderer-48x48x24.jpg
image/jpeg
32
32
24
/LibRygelRenderer-32x32x24.jpg
image/jpeg
128
128
24
/LibRygelRenderer-128x128x24.jpg
image/jpeg
240
240
24
/LibRygelRenderer-240x240x24.jpg
image/jpeg
480
480
24
/LibRygelRenderer-480x480x24.jpg
image/jpeg
600
600
24
/LibRygelRenderer-600x600x24.jpg
/xml/ConnectionManager.xml
/Control/LibRygelRenderer/RygelSinkConnectionManager
/Event/LibRygelRenderer/RygelSinkConnectionManager
/xml/AVTransport2.xml
/Control/LibRygelRenderer/RygelAVTransport
/Event/LibRygelRenderer/RygelAVTransport
/xml/RenderingControl2.xml
/Control/LibRygelRenderer/RygelRenderingControl
/Event/LibRygelRenderer/RygelRenderingControl
http://192.168.1.55:80/
DMR-1.51
1
0
QPlay:2
Naim ND5 XS 2
Naim Audio
ND5 XS 2
20-015-0044
471370
image/png
120
120
24
image/png
48
48
24
image/png
32
32
24
image/png
128
128
24
image/png
240
240
24
image/png
480
480
24
image/png
600
600
24
image/jpeg
120
120
24
image/jpeg
48
48
24
image/jpeg
32
32
24
image/jpeg
128
128
24
image/jpeg
240
240
24
image/jpeg
480
480
24
image/jpeg
600
600
24
DMR-1.51
UPnP devices found : 3
Device #0: Naim ND5 XS 2
Location: http://192.168.1.55:42411/6a736d54-bac1-4223-a5f6-3c2fa21f8496.xml
Device #1: DESKTOP-B3DJACT
UID: uuid:2ee65826-fbba-497c-ac10-14b02383fc28
Location: http://192.168.1.209:2869/upnphost/udhisapi.dll?content=uuid:2ee65826-fbba-497c-ac10-14b02383fc28
Manufacturer: Microsoft Corporation
Model name: Windows Digital Media Renderer
Device #2: [TV] Samsung Q60 Series Nr 183
UID: uuid:041e4971-e849-4c10-9b4a-7ac852448d1d
Manufacturer: Samsung Electronics
Model name: QE49Q67RALXXN
Max. memory for audio buffers: 4096MB
Device #0: Speakers / Headphones (Realtek High Definition Audio)
Manufacturer: Realtek
Model UID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0292&SUBSYS_102805BD&REV_1000
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{ed79be79-7ddf-48f3-a13b-80b577a9dd62}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Chromecast devices found : 6
Device #0: Woonkamer groep
ID: DnsSd#Google-Cast-Group-0c0c8132bfa34ac8b60213b0aea35edf._googlecast._tcp.local#0
Model name: Google Cast Group
Device #1: Thuisgroep
ID: DnsSd#Google-Cast-Group-61623fbd02674a57b29ae55a353cc512._googlecast._tcp.local#0
Device #2: Reena’s Slaapkamer
Model name: Chromecast Audio
Device #3: Mini
Model name: Google Home Mini
Device #4: Naim ND5 XS 2
Device #5: Huiskamer
