Other apps like Apple Music and Amazon Music play fine to my Status Audio bluetooth phones but not Studio.
Hello @randyps65,
Can you give us more information about the issue you have? Are you able to see your Bluetooth device in Studio? Do you mean that you can’t hear audio while you have selected your device in Studio?
Where would I see that?
If you click on this icon at the bottom right of Studio, are you able to see a your bluetooth device? Make sure it is paired with your computer before clicking on this icon so Studio can see your device properly.
They “are” quality headphones. Just because they’re not Focal wired ones doesn’t mean they are not. I do know as do most that Bluetooth or Airplay do not offer the quality of wired headphones.
i see the icon thank you
