I’m on macOS 12.2 evaluating Audirvana Studio. When playing music (connected to DAC), playback will stop when I click on the Exclusive Audio Access lock button. It will always lock when I start playback. I want the option to be able to play without exclusive access. Is this not possible? I even turned off Exclusive Access toggle in the settings on the Output Device section assuming this is a global setting that makes it always on.
Is this behaving the way it’s suppose to and I don’t understand this feature??
So I think I have this figured out, but I don’t think the way it is presented in the app is quite right.
When I have Exclusive Audio Access enabled in the Output Device settings, it behaves as expected always having exclusive access to the DAC. When I disable this setting, it does not have exclusive access and behaves similar to any other audio application.
Where the confusion lies is with the lock at the bottom of Audirvana. I had the assumption this provided a temporary way of disabling exclusive audio access. However, it ALWAYS locks when playing, and if you unlock it, it ALWAYS forces playback to stop. I don’t see the point in this control. What am I missing?
I’m not sure if it’s quite right, but I found that even though it is showing exclusive access on when playing,
