Sudden stop during playback and track restart from beginning
I am using Audirvana Studio for Mac (v2.5.2) with the following settings: Qobuz streaming to Lumin P1 via DLNA. Sometimes during track playback, Audirvana suddenly stops and restarts the playing from beginning of the same track. I’ve activated the log files and when this event happens, the following warning appears in the logs before track restart.
2023-11-05 10:44:47.434 [debug]: UPnP received audio data request from 957349758 for 1048576 loaded 957735650 from buffer 1 trackId 279
2023-11-05 10:44:47.434 [debug]: UPnP sending audio from 2:49 playing 0:0 loaded to 2:49 from 957349758 for 385892 requested 1048576 loaded 957735650 from buffer 1 trackId 279
2023-11-05 10:44:47.579 [debug]: UPnP received audio data request from 957735650 for 1048576 loaded 0 from buffer 1 trackId 279
2023-11-05 10:44:47.707 [warning]: UPnP failed to send file info for not found fileLoader for trackId 279
2023-11-05 10:44:48.374 [debug]: UPnP polling at end of playing
2023-11-05 10:44:49.401 [debug]: UPnP polling at end of playing
2023-11-05 10:44:50.423 [debug]: UPnP polling at end of playing
2023-11-05 10:44:51.451 [debug]: UPnP polling at end of playing
2023-11-05 10:44:52.473 [debug]: UPnP polling at end of playing
2023-11-05 10:44:53.502 [debug]: UPnP polling at end of playing
2023-11-05 10:44:54.404 [debug]: UPnP Received new transport state STOPPED
2023-11-05 10:44:54.404 [debug]: UPnP Set next Chunk stopped next track 280 for buffer 0 starting at 0
2023-11-05 10:44:54.407 [debug]: UPnP setPlayingBuffer discarded
2023-11-05 10:44:55.010 [debug]: UPnP Success setting AVTransportURI to http://192.168.1.3:49152/audirvana/audio_f_280.dff
2023-11-05 10:44:55.019 [debug]: UPnP Received AVTransportURI change to http://192.168.1.3:49152/audirvana/audio_f_280.dff
2023-11-05 10:44:55.029 [debug]: UPnP Send info for file audio_f_280.dff from buffer 0 trackId 280
2023-11-05 10:44:55.029 [debug]: UPnP open file /audirvana/audio_f_280.dff
2023-11-05 10:44:55.029 [debug]: UPnP webserver: seek 0 bytes from 1 from buffer 0
2023-11-05 10:44:55.029 [debug]: UPnP sent DFF header with fileLength 1825340546 audio data 1825340416 from buffer 0
2023-11-05 10:44:55.029 [debug]: UPnP received audio data request from 0 for 1048446 loaded 82791650 from buffer 0 trackId 280
2023-11-05 10:44:55.029 [debug]: UPnP sending audio from 0:0 playing 0:0 loaded to 0:14 from 0 for 1048446 requested 1048446 loaded 82791650 from buffer 0 trackId 280
2023-11-05 10:44:55.035 [debug]: UPnP Send info for file audio_f_280.dff from buffer 0 trackId 280
2023-11-05 10:44:55.035 [debug]: UPnP open file /audirvana/audio_f_280.dff
2023-11-05 10:44:55.035 [debug]: UPnP webserver: seek 130 bytes from 1 from buffer 0
2023-11-05 10:44:55.035 [debug]: UPnP received audio data request from 0 for 1048576 loaded 82791650 from buffer 0 trackId 280
2023-11-05 10:44:55.035 [debug]: UPnP sending audio from 0:0 playing 0:0 loaded to 0:14 from 0 for 1048576 requested 1048576 loaded 82791650 from buffer 0 trackId 280
2023-11-05 10:44:55.070 [debug]: UPnP received audio data request from 1048576 for 1048576 loaded 82791650 from buffer 0 trackId 280
Hi @rmi,
