Here are suggestions on the user interface.
I think the width of windows, such as the playlist window should reopen with the same width it had last time used. I find myself resizing that window every time I change views, like going to tracks.
I also think that one should be able to anchor in the window the metadata window, like it was in the previous version. The information suggested is great. I would just offer a version where the extended info appears underneath the General window, so one could see bothe at the same time. Perhaps you should make it possible to make it thinner as well.
Also on the metadata window, It would be nice that the return key would make the window save.
