Hello. Meridian no longer supports Sooloos for the newer MacOS. With a new iMac, I can no longer access my extensive music library which is stored on a Qnap TS-453A. Is there anyone out there who has successfully made the switch to the Audirvāna music managing system. If so, was the process seamless and easy? Cheers, Colin
Hello @Savagino ,
Are you able to see your Qnap in Finder? If it’s the case then you will be able to add it to Studio in the local section of Studio.
