I want to synchronize my two Astell & Kern Players with Audirvana!
In the best case like I sync my old iPod with iTunes.
Until now I’d used iTunes and spend a lot of time to convert my FLAC in the lossless m4a files.
After this I used a Software called Dapper to sync the iTunes library with the SD Card of my Astell & Kern Players.
Unfortunately iTunes does not share the XML file after switching to Catalina.
So I’m searching to any alternative - hopefully Audirvana can do this on any way!
Hello @dacato, you want to use the file in your A&K in Audirvana and use your DAP to play your music or you only want to see the files stored in your A&K in Audirvana?
I want to synchronize the content from my Audirvana to the Astell&Kern Player, like playlists and so on.
In the past I did it with iTunes and my iPods and now I’m searching for a FLAC Alternative!
