I use another app for ripping/downloading/cataloguing my music. With AO, every time I make a small change to the metadata in this app (e.g. āRatingā), AO syncs the change immediately and the change shows up in my AO library. However, with AS, syncing stops around the 95% mark and just hangs. Something is really hanging at this point because AS wonāt close (top right red button), so I have to close it from the Windows taskbar. Then, it takes a while before it can he opened again.
Hi @rafs,
Can you send us a copy of the "Debug Infoā when you have this issue? You can get it in Audirvana Settings>My account.
Audirvana Studio 2.10.2 (21002)
Windows 10 (19045) x86_64 with 16GB physical RAM
Connected account of : Rick
Available network interfaces:
Ethernet ({ded6ff6c-0811-42f9-a782-0b43fe49c734}) is private
Active profile types: all
Private profile:
Firewall: enabled
Inbound: blocked
Outbound: allowed
Notifications: enabled
Public profile:
Firewall: enabled
Inbound: blocked
Outbound: allowed
Third party firewall installed and registered in place of Windows Defender:
Bitdefender Firewall
SoX to DSD256 with filter type A 4th order
Bandwidth at 0dB = 94.5962%
Filter max length = 23429
Anti-aliasing = 96.044
Phase = 66%
Sync list: 2 folders
AUTO: Q:
AUTO: R:
Sync folders at startup: NO
Sort and display order: en_US
Library database path: C:\Users\User\AppData\Local\Packages\Audirvana.Audirvana-4118-9684-d80dbb7827cd_q3nymrkmej12j\LocalCache\Local\Audirvana\Audirvana\AudirvanaDatabase.sqlite
R:\Music\Jaco Pastorius - Jaco Pastorius (2022) FLAC
Deep Synch: no
Completing scan: cleaning
Fingerprinting track 42848/189727 : R:\Music\Gualberto - A La Vida, Al Dolor (1975)\Gualberto - A La Vida, Al Dolor (3 - Cancion de la nieve).flac
Listening on 2604:3d08:5d82:6400:9158:ff:1aaa:5e13 on port 51783
Font size: regular
My Music
Radios
Podcasts
Streaming
Startup view: Last displayed view
Number of paired remotes: 0
Screen saver disabled: no
Max. memory for audio buffers: 8192MB
Speakers (Eversolo DAC-Z8)
Model UID:USB\VID_20B1&PID_30FD&REV_0117&MI_00
UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{e11e88f6-9321-44b0-8711-aca2f1774de6}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Selected device:Speakers (3- Scarlett 2i2 USB)
Manufacturer: Microsoft
Model name: Scarlett 2i2 USB
Model UID: USB\VID_1235&PID_8016&REV_01><&MI_00
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{b6c5af5e-bdf5-42d3-8e92-c3fe066ff22e}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
USB Vendor ID: 0x1235
USB Product ID: 0x8016
Kernel Streaming capable
DSD via PCM 1.0
Simple stereo device: No
Local devices found : 3
Device #0: Speakers (3- Scarlett 2i2 USB)
Device #1: Realtek Digital Output (Realtek(R) Audio)
Manufacturer: Realtek
Model UID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0897&SUBSYS_104387FB&REV_1004
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{153f2dd6-31b7-4d90-b848-ef77601dc919}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #2: Speakers (Realtek(R) Audio)
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{0fa9d09c-37d5-4f97-b4a3-8bfd72babfd5}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Ethernet
UPnP devices found : 1
Device #0: OFFICE-DESKTOP-2021
UID: uuid:6143b510-15ca-48aa-b3d1-176fb8716832
Location: http://10.0.0.160:52101/DeviceDescription.xml
Manufacturer: JRiver, Inc.
Model name: Media Center
I have just reinstalled AS, and the same thing is still happening.
Do you have all the tracks in this folder synced?
All 11 tracks copied over from JRMC and show up in AS. Interesting you should mention this albumā¦I think the problem started when I made a change to its tag (āRatingā change). Thatās when I first saw AS hang.
in the image it is syncking The Brecker Brothers album⦠maybe Audirvana doesnāt like that apostrophe in the titleā¦
Well, it was happening before I added this album to AS, so I donāt think itās the apostrophe
UPDATE: Stitched back over to AO, and this problem does not occur there, so itās something going on with AS only.
Can you go into the AudirvÄna settings and in the My Account section? You will see a āStart Log Sessionā button; click on it and reproduce your issue. After you reproduce it, click 'Stop Log Sessionā and send me the audirvana_studio.log file at [email protected], which you can find by clicking the 'Open Log Folderā button.
Any further updates on this one, Antoine?
UPDATE: Iām still playing around with this one. AS still stops syncing completely whenever I make a metadata change in JRiver that should normally just copy over immediately into Audirvana. In this case āRatingā. It works seamlessly in AO. Now I can see that AS stops syncing if I make the change to an album while that album is displayed and playing. If I select a different album (and even with the original album still playing) and therefore the first is no longer displayed, the change copies over. Strange one, right? How can it happen so consistently in AS (after several reinstalls) but never in AO? And has anyone else noticed this?
