Here’s the debug Info:
Registered to David xxxxxxx
Per track: OFF
AUTO: /Volumes/Music Vault/RDG Music
Library database path: /Users/Stereo/Documents/AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 8950MB
X-SPDIF 2
Model UID:X-SPDIF 2:20B1:2004
UID:AppleUSBAudioEngine:Matrix Audio:X-SPDIF 2:14100000:1
Sample rate limitation: 96kHz
Limit bitdepth to 24bit: ON
ID 0x2e X-SPDIF 2 Manufacturer:Matrix Audio
Model UID:X-SPDIF 2:20B1:2004 UID:AppleUSBAudioEngine:Matrix Audio:X-SPDIF 2:14200000:1
Stream ID 0x2f 2 channels starting at 1
30 virtual formats:
40 physical formats
Local devices found : 4
Device #0: ID 0x4c Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:88 UID: AppleHDAEngineOutput:1B,0,1,2:0
Device #1: ID 0x2e X-SPDIF 2 Manufacturer: Matrix Audio Model UID: X-SPDIF 2:20B1:2004 UID: AppleUSBAudioEngine:Matrix Audio:X-SPDIF 2:14200000:1
Device #2: ID 0x37 Mixlr AudioLink Manufacturer: Mixlr Model UID: com_mixlr_driver_MixlrAudioDevice:Mixlr UID: MixlrAudioEngine:0
Device #3: ID 0x2a Jump Desktop Audio Manufacturer: Phase Five Systems LLC Model UID: com.p5sys.jump.audio.driver UID: com.p5sys.jump.audio.driver_v001
UPnP devices found : 1
Device #0: ID 0x0 [TV] Samsung 7 Series (65) UID: uuid:e7eb365a-a2ac-468c-acc5-e2938f3f5b39 Location: http://192.168.1.111:9197/dmr
