macOS 11.6.0 with 8192MB RAM
Registered to S PADMESH
Sync list: 0 folders
Library database path: /Users/padmesh/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Helm MQA
Model UID:Helm MQA:2454:129B
UID:AppleUSBAudioEngine:Helm Audio:Helm MQA:20191209:1
Device: 2ch Non-mixable linear PCM Interleaved 24bits little endian Signed Integer, 6 bytes per frame 88.2kHz
Active Sample Rate: 88.2kHz
Hog Mode is on
ID 0x49 Helm MQA Manufacturer:Helm Audio
Model UID:Helm MQA:2454:129B UID:AppleUSBAudioEngine:Helm Audio:Helm MQA:20191209:1
Audio buffer frame size : 116 to 4096 frames
MQA Renderer device
Stream ID 0x4a 2 channels starting at 1
32 virtual formats:
48 physical formats
2 ch Mixable linear PCM Interleaved 24 little endian Signed Integer 384kHz
2 ch Mixable linear PCM Interleaved 24 little endian Signed Integer 352.8kHz
Device #0: ID 0x32 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:123 UID: AppleHDAEngineOutput:1B,0,1,1:0
Device #1: ID 0x49 Helm MQA Manufacturer: Helm Audio Model UID: Helm MQA:2454:129B UID: AppleUSBAudioEngine:Helm Audio:Helm MQA:20191209:1
