macOS 14.3.1 with 16384MB RAM
Polarity
Inversion:
Globaly: OFF
Sox not lin use
Fiter max length = 30000
Ant-allasing = 100
Hello,
Audirvana requires SysOptimizer to be installed. But the installation ends with a crash “error, operation could not complete ossStatus error 80”.
What can I do?
Thank you.
Hi @citi888,
To fix this permission issue, you can use the Terminal application (you can find it in Application>Utilities) and enter the following commands:
sudo chgrp wheel /Library/PrivilegedHelperTools
sudo chmod 1755 /Library/PrivilegedHelperTools
If it’s still not working can you close Audirvana and do the three commands below in Terminal ?
sudo launchctl load -w /Library/LaunchDaemons/com.audirvana.SysOptimizerTool.plist
sudo rm /Library/PrivilegedHelperTools/com.audirvana.SysOptimizerTool
sudo rm /Library/LaunchDaemons/com.audirvana.SysOptimizerTool.plist
After doing this, can you open Audirvana and play a track?
