Getting “SysOptimizer Error (OSStatus error -1)” errors since I went up one version in AV Origin (to 2.3.0). All was fine before, running on Mac mini late 2014, Monterey 12.4. Same DAC, etc.
Help please?
Thank you
Pierre
Debug info as follow;
Audirvana Origin 2.3.0 (20300)
macOS Version 12.4 (Build 21F79) with 16GB physical RAM
Connected account of : xxxxx
r8brain custom frequencies
Sync list: 2 folders
AUTO: /Users/pierrelavoie/Music/CDs
AUTO: /Volumes/T7/Music/Hi Res
Library database path: /Users/pierrelavoie/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 59348
Local Audio Engine: CoreAudio
Exclusive access: ON
Integer mode: ON
Use max I/O buffer size: OFF
HOLO AUDIO HOLO AUDIO UAC2.0 GEN2.1 ENHANCED
Model UID:Holo Audio UAC2.0 Gen2.1 Enhanced:152A:87C0
UID:AppleUSBAudioEngine:Holo Audio:Holo Audio UAC2.0 Gen2.1 Enhanced:14610000:1
Device: 2ch Non-mixable linear PCM Interleaved 32bits little endian Signed Integer, 8 bytes per frame 176.4kHz
Active Sample Rate: 176.4kHz
Hog Mode is on
Selected device:Holo Audio UAC2.0 Gen2.1 Enhanced
Manufacturer: Holo Audio
Model name: Holo Audio UAC2.0 Gen2.1 Enhanced
Model UID: Holo Audio UAC2.0 Gen2.1 Enhanced:152A:87C0
UID: AppleUSBAudioEngine:Holo Audio:Holo Audio UAC2.0 Gen2.1 Enhanced:14610000:1
USB Vendor ID: 0x152a
USB Product ID: 0x87c0
ID 0x3c
12 available sample rates up to 1536000Hz
1411200
1536000
Max volume alert: Disabled
Stream ID 0x3d 2 channels starting at 1
24 virtual formats:
2 ch Mixable linear PCM Interleaved 32 little endian Signed Float 1536kHz
2 ch Mixable linear PCM Interleaved 32 little endian Signed Float 1411.2kHz
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 1536kHz
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 1411.2kHz
24 physical formats
2 ch Mixable linear PCM Interleaved 32 little endian Signed Integer 1536kHz
2 ch Mixable linear PCM Interleaved 32 little endian Signed Integer 1411.2kHz
Local devices found : 3
Device #0: ID 0x2b Built-in Output
Model UID: AppleHDA:108
Device #1: ID 0x3c Holo Audio UAC2.0 Gen2.1 Enhanced
Device #2: ID 0x32 xCORE USB Audio 2.0
Manufacturer: XMOS
Model UID: xCORE USB Audio 2.0:20B1:000A
UID: AppleUSBAudioEngine:XMOS:xCORE USB Audio 2.0:14700000:1
USB Vendor ID: 0x20b1
USB Product ID: 0x000a
Model name: XMOS xCORE USB Audio 2.0
