Hi Damien, recently I keep getting this message. After pressing ok, everything sounds ok and is working. What does it mean and what to do?
Thanks, Rudi
Thanks, Rudi
Can you use the Terminal application and enter the following commands:
sudo chgrp wheel /Library/PrivilegedHelperTools
sudo chmod 1755 /Library/PrivilegedHelperTools
Hi Damien,
I have no idea what I did entering the command in Terminal, but the problem seems fixed!
This is related to permissions, using the command add the proper one so Audirvana can use SysOptimizer properly.
