I reinstalled Origin again.
Now it’s waiting for someone to give a solution to be able to listen to music again.
I’m having same problems as others. Here’s my Debug Info:
Audirvana Origin 2.2.2 (20202)
macOS Version 13.1 (Build 22C65) with 16GB physical RAM
Connected account of : Tim Stapleton
AUTO: /Volumes/timchristinestapleton/Music/Audio Library - T & C Stapleton
iTunes/Music library synchronization: last synchronized on Mon Jun 13 16:46:03 2022
Library database path: /Users/tandc/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 49163
Max. memory for audio buffers: 15360MB
Local Audio Engine: CoreAudio
Exclusive access: ON
Integer mode: ON
ATM MRX 740
Model UID:068D0100-0000-0000-001E-010380000078
Active Sample Rate: 48kHz
Limit bitdepth to 24bit: ON
Selected device:MRX 740
Manufacturer: ATM
Model name: ATM MRX 740
Model UID: 068D0100-0000-0000-001E-010380000078
ID 0x4a
6 available sample rates up to 768000Hz
32000
Stream ID 0x4b 2 channels starting at 1
7 virtual formats:
3 ch Mixable linear PCM Interleaved 32 little endian Signed Float 48kHz
4 ch Mixable linear PCM Interleaved 32 little endian Signed Float 48kHz
5 ch Mixable linear PCM Interleaved 32 little endian Signed Float 48kHz
6 ch Mixable linear PCM Interleaved 32 little endian Signed Float 48kHz
7 ch Mixable linear PCM Interleaved 32 little endian Signed Float 48kHz
8 ch Mixable linear PCM Interleaved 32 little endian Signed Float 48kHz
21 physical formats
3 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 48kHz
4 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 48kHz
5 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 48kHz
6 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 48kHz
7 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 48kHz
8 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 48kHz
3 ch Mixable linear PCM Interleaved 20 little endian Signed Integer aligned low in 32bit 48kHz
4 ch Mixable linear PCM Interleaved 20 little endian Signed Integer aligned low in 32bit 48kHz
5 ch Mixable linear PCM Interleaved 20 little endian Signed Integer aligned low in 32bit 48kHz
6 ch Mixable linear PCM Interleaved 20 little endian Signed Integer aligned low in 32bit 48kHz
7 ch Mixable linear PCM Interleaved 20 little endian Signed Integer aligned low in 32bit 48kHz
8 ch Mixable linear PCM Interleaved 20 little endian Signed Integer aligned low in 32bit 48kHz
3 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 48kHz
4 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 48kHz
5 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 48kHz
6 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 48kHz
7 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 48kHz
8 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 48kHz
Device #0: ID 0x4a MRX 740
Manufacturer: ATM
Device #1: ID 0x44 Mac mini Speakers
Model UID: Speaker
UID: BuiltInSpeakerDevice
UPnP devices found : 1
Device #0: ID 0x0 : MRX 740-41FC56
UID: uuid:8ec6e5c5-f1b0-4800-9fe3-092c77eac6c3
Location: http://192.168.1.107:37121/8ec6e5c5-f1b0-4800-9fe3-092c77eac6c3.xml
Manufacturer: Anthem
Model name: MRX 740
Chromecast devices found : 1
Device #0: MRX 740-41FC56
Model name: MRX 740
Another question is when the problem is solved in Origin if it will also be solved in v3.5
Many like me use both versions.
Seems like Apple tightened some security screws in 13.1…
Same here, this unfortunately didn’t help.
Don’t worry about it. I always used Audirvana without Sysoptimizer and it works perfectly regardless.
The only way to make it work is to leave it disabled.
But it’s too bad, almost every time an update comes out on MacOS something happens.
Hi everyone, I got some news for you.
It’s seems on the latest version of Ventura, a command we use for a part of SysOptimizer is returns an error although it succeeds thanks to Apple 13.1 update. They will eventually fix it one day.
We fixed this issue in the 2.2.3 version of Audirvāna Studio/Audirvāna Origin (you will need to enable again Disable Spotlight and play a song)
For legacy version you will need to toggle off the option “Disable Spotlight” in the SysOptimizer if you don’t want to see this false warning message.
Il semble que sur la dernière version de Ventura, une commande que nous utilisons pour une partie de SysOptimizer renvoie une erreur bien qu’elle réussisse grâce à la mise à jour 13.1 d’Apple. Ils finiront par corriger ce problème un jour.
Nous avons corrigé ce problème dans la version 2.2.3 d’Audirvāna Studio/Audirvāna Origin (vous devrez réactiver la fonction “Disable Spotlight” et jouer une chanson).
Pour les anciennes versions, vous devrez désactiver l’option “Désactiver Spotlight” dans SysOptimizer si vous ne voulez pas voir ce faux message d’alerte.
Hello,
Lorsque je lance la lecture d’un morceau (Sur MacOS Ventura), j’ai cette fenetre qui s’ouvre
Erreur lors de l’exécution de SysOptimizer. Toutes les optimisations n’ont pas pu être effectuées.
Erreur : L’opération n’a pas pu s’achever. (OSStatus erreur 22.)
J’ai lu le post qui passe par le terminal et fait entrer 3 lignes de code mais ca n’a in aangé hz moi (malgré la réinstallation Syoptimiser au lancement…)
Quelqu’un a une idée de quoi faire ?
Cdt,
Bonjour @Antoine
J’ai bien désactivé l’item Spotlight dans les réglages mais l’erreur revient quand même.
Bon tant que ca ne gène pas la lecture ce n’est pas dramatique, on attendra une MaJ qui rèleral le souci.
Au passage je suis sur la 3.5.50.
Super merci je redescends vers 2,2,1
In case you missed this, @Antoine’s advice to toggle off the “Disable Spotlight” option fixes the SysOptimizer issue for me using Origin 2.2.2 and Ventura 13.1. You don’t need to turn off “Allow in the Background” for Audirvana. An excellent workaround until @Antoine provides a bandaid for Apple’s problem in the next Origin release.
When you turn off allow in background in macos, and then start Audirvana, it will ask you to install the SysOpt, good thing. but it will ask at every start to install it, so after you install it once you put back ON allow in background. Plays perfectly since like before.
Since then all is normal and i didn’t put Spotlight at off. All is on on extreme settings like before.
@RunHomeSlow
I tried the procedure you wrote, but it didn’t work for me.
I tested with version 2.2.1 as with version 2.2.2
I know, it might happens, as i didn’t wrote every step i tried… before success, like after putting the macos pref, did i restart before i put it back on?? Anyway that should not happen first, but will be adresses in a next update I’m sure.
Try @Antoine’s advice of toggling off the “Disable Spotlight” option. This worked for me and no other adjustments were necessary.
Thanks, Antoine
