Also,
Go to the Main Library Folder⦠PrivilegedHelperTools folderā¦
Go to the Main Library Folder⦠LaunchDaemons Folderā¦
Also,
Clean uninstall & reinstall Audirvana with āBuhoCleanerā
Restart Mac including First Aid in Disk Utility (no problem)
When Spotlight and Time Machine are enabled, this error does not happen.
I want keep those things disabled when I listening though.
Audirvana Studio 2.2.2 (20202)
macOS Version 13.1 (Build 22C65) with 32GB physical RAM
At first, it didnāt work after all that plus the reboot. But today after another reboot, it seems to work. No error message. However it took a full 2 minutes for the program to open after I clicked on it.
I mostly use Roon now to play my HD files. With a monthly subscription I can download any song that I can find in their database, or in Tidal which also needs a subscription. But with Roon I can play the music on my computer, my iPhone, iPad, my stereo and my streamer. Nice interface and it will recommend music based on my listening.
I solved this problem by using āAudirvana studio 2.2.2 on M1 mac Venturaā and changing the āOptimize System for Audio Playbackā to off in the settings as shown in the image below.
Yes, thatās an idea: if you disable a buggy feature, the bug normally wonāt show up again (With SW āa la MSā though you never knowā¦).
But in that case, the AS sound may be not as good as it should be, due to parralel activities in the background.
It would be interesting to know from the development team the possible root cause of the problem.
Ok, just to let you know, I moved to the latest MacOS (Ventura), and the problem with SysOptimizer (Popup when you try to play something, which by the way is not seen from Remote) is still there.
Only option: reboot the Mac.
Hi guys, If you have not already, I added the link to a test version that fix this issue. For those having the issue, please try the version and feel free to comment on this thread whether it worked or not
