Hi Im running latyes macos and latest Audirvana.
Connected mac to das by usb.
Wanted to try upsampling mode
System asked for password,mac password or appleid is not working not idea what password it asked for.
If anybody know solution let me know ,everything else working fine so far.
Im supprised that ther is no contact to develpoer only forum its not cheap soft so shpuld be possible ask tech questions directly.
Hello @Cezary_Jenczelewski,
Can you disable the Time machine option and use the Terminal application and enter the following commands:
sudo chgrp wheel /Library/PrivilegedHelperTools
sudo chmod 1755 /Library/PrivilegedHelperTools
