it takes almost 3 minutes to open the app and then it will not open local files on the app. they will open on the local computer.
log file is below:
Audirvana Studio 2.3.4 (20304)
macOS 13.3.1 with 8GB physical RAM
Connected account of : paul adams
Per track: OFF
AUTO: /Volumes/WSCrucial4/Music
Library database path: /Volumes/WSCrucial4/audirvanadb/AudirvanaDatabase.sqlite
Deep Synch: yes
Scanning 22404/195875: /Volumes/WSCrucial4/Music/Buddha-Bar/Buddha Bar, Vol. 1/Buddha Bar, Vol. 1 Disc 1/02 Sina Vodjani - Straight to the Heart.flac
Fingerprinting track 349/14156 : /Volumes/WSCrucial4/Music/2011 - 25 Years/CD 1/09 - Be Still My Beating Heart.flac
Listening on 127.0.0.1 on port 49654
Max. memory for audio buffers: 5992MB
Local Audio Engine: CoreAudio
Exclusive access: ON
Integer mode: ON
Chord Electronics Ltd Mscaler
Model UID:Mscaler:245F:0815
UID:AppleUSBAudioEngine:Chord Electronics Ltd:Mscaler:413-001:2
Device: 2ch Non-mixable linear PCM Interleaved 32bits little endian Signed Integer, 8 bytes per frame 96kHz
Active Sample Rate: 96kHz
Hog Mode is on
Selected device:Mscaler
Manufacturer: Chord Electronics Ltd
Model name: Chord Electronics Ltd Mscaler
Model UID: Mscaler:245F:0815
UID: AppleUSBAudioEngine:Chord Electronics Ltd:Mscaler:413-001:2
USB Vendor ID: 0x245f
USB Product ID: 0x0815
ID 0x33
11 available sample rates up to 768000Hz
32000
Max volume alert: Disabled
Stream ID 0x34 2 channels starting at 1
22 virtual formats:
22 physical formats
Device #0: ID 0x33 Mscaler
Device #1: ID 0x58 Mac mini Speakers
Model UID: Speaker
UID: BuiltInSpeakerDevice
