Thank you Antoine,
Please see debug report below. Oddly since I’ve posted my question/issue about the Clarity M plugin, I encountered a new issue which I’ve never seen since I got Audirvana about a year or two ago. Recently I was listening to Tidal via Audirvana as I always have. I looked up an artist, selected a track and it failed to load. After a minute or so, Audirvana started playing the track below my selection in the playlist. I reinstalled a slightly older 3.5.43 and the problem went away for a little bit, but still occurs time to time. Very odd, this has never happened before. The Clarity plugin not loading is somewhat of an issue. I can still meter via optical, but the recent issue with loading tracks is more concerning. Maybe the debug report can shed some insight on both matters?
I will send the clarity installer via email to support@audirvana.com
macOS 11.6.0 with 16384MB RAM
Sync list: 0 folders
Library database path: /Users/marcinnowak/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 12522MB
Exclusive access: Disabled
Integer mode: Disabled
Lynx Hilo
Model UID:Lynx Hilo:247F:3231
UID:AppleUSBAudioEngine:Lynx:Lynx Hilo:3203932283:1,2
Active Sample Rate: 96kHz
ID 0x76 Lynx Hilo Manufacturer:Lynx
Model UID:Lynx Hilo:247F:3231 UID:AppleUSBAudioEngine:Lynx:Lynx Hilo:3203932283:1,2
Multichannel: 8 channels
Preferred stereo channels L:3 R:4
Channel 2 unused
Channel 3 unused
Channel 4 unused
Channel 5 unused
Channel 6 unused
Channel 7 unused
Number of channels: 8
Simple stereo device: No
Channel #0 :Stream 0 channel 2
Channel #1 :Stream 0 channel 3
Stream ID 0x77 8 channels starting at 1
12 virtual formats:
8 ch Mixable linear PCM Interleaved 32 little endian Signed Float 192kHz
8 ch Mixable linear PCM Interleaved 32 little endian Signed Float 176.4kHz
8 ch Mixable linear PCM Interleaved 32 little endian Signed Float 96kHz
8 ch Mixable linear PCM Interleaved 32 little endian Signed Float 88.2kHz
8 ch Mixable linear PCM Interleaved 32 little endian Signed Float 48kHz
8 ch Mixable linear PCM Interleaved 32 little endian Signed Float 44.1kHz
8 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 192kHz
8 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 176.4kHz
8 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 96kHz
8 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 88.2kHz
8 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 48kHz
8 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 44.1kHz
12 physical formats
8 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 192kHz
8 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 176.4kHz
8 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 96kHz
8 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 88.2kHz
8 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 48kHz
8 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 44.1kHz
Local devices found : 7
Device #0: ID 0x72 BL450 Manufacturer: Apple Inc. Model UID: AppleGFXHDA:0 UID: AppleGFXHDAEngineOutputDP:f803:0:{6D1E-5B86-000CD2C1}
Device #1: ID 0x76 Lynx Hilo Manufacturer: Lynx Model UID: Lynx Hilo:247F:3231 UID: AppleUSBAudioEngine:Lynx:Lynx Hilo:3203932283:1,2
Device #2: ID 0x39 BlackHole 16ch Manufacturer: Existential Audio Inc. Model UID: BlackHole16ch_ModelUID UID: BlackHole16ch_UID
Device #3: ID 0x40 BlackHole 2ch Manufacturer: Existential Audio Inc. Model UID: BlackHole2ch_ModelUID UID: BlackHole2ch_UID
Device #4: ID 0x6c Mac mini Speakers Manufacturer: Apple Inc. Model UID: Speaker UID: BuiltInSpeakerDevice
Device #5: ID 0x4c Dolby Audio Bridge Manufacturer: Dolby Model UID: DABASPDevice_ModelUID UID: DABASPDevice_UID
Device #6: ID 0x47 Dirac Virtual Audio Device Manufacturer: Dirac Research AB Model UID: com.dirac.vad_ModelUID UID: com.dirac.vad_UID
