Thanks for “not try to select RAW PCM stream format when playing in UPnP” - My ARCAM DAC is life again !
28th I will start my subscription.
This version has solved the Qobuz selection issue for which I am very grateful. The new UPnP setting has not helped with the Cambridge CXN V2 however. I am hoping that update will come at some point.
My Oppo 205 has accepted streaming with UPnP since Studio launch but with the Cambridge nada. UPDATE: I have finally got UPnP streaming to the CXN v2. I didn’t do anything (I had already activated the no RAW feature). so not sure if it will continue
I thought it was too good to be true. Although it played the sound was not good and it skipped to the next track part way through the first. So near but yet so far.
