When I am in the iOS version of the remote app and switch among Home, Search, Favorites & Settings, when I switch back to one of these four views, whatever I was viewing under that view last time I was there is preserved. Say I search for Beatles Abby Road under Search | Tidal and then switch to Home, and get into Home | Local | album XZY, then switch to Favorite to open playlist ABC, then got to Settings to change the playback device. I then switch, back to Home, I would be in local album XYZ. If I switch to Favorite, I will be in playlist ABC and so on. The views are reset only if I exit the remote app and re-open it.
This does not work in the Android remote. Every time I switch view and back, I lost whatever I was looking at in that view and had to navigate or search all over again.
This has been a major annoyance to a point I no longer use Audirvana and switch to Roon. But I have UPnP renderers and really need Audrivana. I thought this was a universal problem with the remote app until I borrowed an i-device and realized this is an issue only with the Android version. If Dev team sees this, please fix this issue. Or if this is the wrong venue, how do I open a support request ticket for a fix?
I am running Audirvana 3.5.44, Android remote (v1.2.6). iOS remote tested (v2.3).
