Does anyone tried different settings with gold phantom, and then wich ones are the perfect settings ?
I have Phantoms (Silvers) and I have found that sending the files via PnP, sounds best. Plus, I can tweak the sub bass a bit using AU EQ since my Silvers can easily overwhelm my room with bass.
