1 When the search box is empty the search button should be disabled. currently clicking it with no input produces an exception.
3. The now playing section should have an option to add to a playlist.
4. The playlist information should be retained when source folder goes offline. ( The source got disconnected due to network mapping and when i re-connected the playlist was empty. super annoying)
5. Player should not start in maximized mode.
6. When navigating the menus clicking back should not make the scroll bars start from the top. The position of the list should be remembered.
I have stopped using jriver and prefer now to use Audirvana because i feel the sound is better however the quirks need to be worked out especially things like playlists etc.
Vous avez bien la build 1027? Enfin, maintenant la 1028. Et la mémorisation de la position est uniquement pour la bibliothèque locale, pas les services de streaming
