Ticking noises during playback to Chromecast Audio
Can anyone give me some advice how to get rid of these random high ticking noises during playback. I am new to Audirvana Studio, but am an absolute fan of Audirvana 3.5 for years now.
Today, after installing the v.2.3 trail and playing some my music HD files I randomly hear ticking sounds randomly coming from either my left and/or right speaker. My output goes to a Chromecast Audio, connected within a single ended Ethernet wired network.
After some testing using either the DNLA/Upnp or Chromecast protocol it only occurred while “casting” directly to my Chromecast Audio, which is a new feature since Audirvana Studio/Origin 2.0. @Antoine Is this a common phenomenon?
I will continue to test, because my experience of the R8 sound is quite positive and favorable in comparison with Sox in Audirvana 3.5. Keep up the good work!
Hi @E.Abrahamse,
Hi Antoine,
Thank you for your quick response. I send you the Debug info scan from today. I have investigated what could have an impact on these ticks. As far as I have experienced up till now they occur randomly. It is not dependent on file size, nor sample rate or sample frequency. I have played various albums in MP3 up till DSD512. Now I stream to the Chromecast Audio exclusively (not via BubbleUPnP). These high pitching ticks are only occurring while using Audirvana Studio in conjunction its new Direct Chromecast feature.
I happen to be an audible hyper sensitive as small imperfections and glitches are heard immediately by me. Maybe you can shed some light on possible solutions. I am loving the gapless playing in this Chromecast mode.
As you already know, my ‘no connection’ has been resolved by restarting my network amongst other checks.
Have a nice weekend, to all of you on Audirvana.com!
Kind regards, Erwin
Audirvana Studio 2.3.0 (20300)
macOS 12.6.5 with 24GB physical RAM
Connected account of : Erwin Abrahamse
            Per track: OFF
Phase minimum phase
SW volume control: ON
Sync list: 2 folders
AUTO: /Users/erwinabrahamse/Music/Muziek (Audirvana)
AUTO: /Volumes/music/
Library database path: /Users/erwinabrahamse/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
/Volumes/music
Deep Synch: yes
Intializing
Tracks with no MBID: 92395
Listening on 127.0.0.1 on port 49510
Max. memory for audio buffers: 4066MB
Local Audio Engine: CoreAudio
Exclusive access: ON
Integer mode: ON
Apple Inc. Built-in Output
Model UID:AppleHDA:130
UID:AppleHDAEngineOutput:1F,3,0,1,2:0
Sample rate limitation: 96kHz
Selected device:Built-in Output
Model UID: AppleHDA:130
UID: AppleHDAEngineOutput:1F,3,0,1,2:0
ID 0x4d
Stream ID 0x4e 2 channels starting at 1
4 virtual formats:
16 physical formats
Device #0: ID 0x4d Built-in Output
Device #1: ID 0x42 AudioQuest DragonFly Red v1.0
Manufacturer: AudioQuest
Model UID: AudioQuest DragonFly Red v1.0:21B4:0082
UID: AppleUSBAudioEngine:AudioQuest:AudioQuest DragonFly Red v1.0:AQDFRD0100105172:1
USB Vendor ID: 0x21b4
USB Product ID: 0x0082
Model name: AudioQuest DragonFly Red v1.0
UPnP devices found : 1
Device #0: ID 0x0 : Huiskamer (DLNA)
UID: uuid:a564b544-c68b-c2b7-ffff-ffff972f1e99
Location: http://192.168.101.5:49734/dev/a564b544-c68b-c2b7-ffff-ffff972f1e99/desc.xml
Manufacturer: Bubblesoft
Model name: BubbleUPnP Google Cast DLNA renderer
Chromecast devices found : 1
Device #0: Huiskamer
Model name: Chromecast Audio
@Antoine After having tested Audirvana Studio 2.3, I am very, very happy with the overall sound and soundstage on my system. The high ticking noises still occur on a regular basis.
What is quite interesting is that Audirvana Studio 2.3 is far less stable than Audirvana 3.5. It crashed violently on me for 3 times in the last week or so. Audirvana 3.5.50 never crashed to my knowing.
It is also less responsive (beach balling) in many occasions on a iMac I7 with 24 Mb of memory. The cache I set for preloading is 4Mb. Does this setting have any impact on sluggishness whatsoever?
Could you please look into this matter? If you need more feedback (like bug reports with the next crash, please let me know. Your help is tremendously appreciated as it could also address general issues.
Ok, then I will need the crash log generated by Audirvāna Studio when you have the crash. You can find it in the Console app of MacOS under the utilities folder in the applications.
Please send the crash log at support@audirvana.com
