Hi
After my upgrade to 2.6.2, tidal hires flac was playback at lower resolution from audirvana. See the screenshot
Playing direct from tidal show 24 bit/192 kHz but in Audirvana only play at 24/48
(Ver 2.6.0 playing with full resolution)
Hi
I had exactly the same problem. If you go to configuration - streaming, you will see that Tidal is set to HiFi, and then to Max. Disconnect and connect again. You will now see HiFi Plus - and then you will have full resolution (make sure you are still at max)
