Hello,
I’m running Audirvana 3.5.4 on Windows 10, and I’m logged in with my Tidal subscription.
When I stream albums from Tidal and click the button on the bottom right corner of the screen which brings me to the list of preloaded tracks, Audirvana shows the bit depth and sampling rate of all tracks as zero:
Additionally, no DR or Dynamic Range information are available.
Is it possible to fix this?
Bit depth/Sampling rate aren’t a big deal as I can see them anyway on the bottom left corner of the screen (which is limited to track being played, but it’s reasonable to assume the entire album will be in the same format), but it does look a bit strange
DR/Dynamic Range would be very nice to have, if it is possible to retrieve the information from Tidal or analyze the tracks in some way.
