Thank you for your quick response! Debug info below.
Audirvana Studio 2.6.5 (20605)
macOS 14.2.1 with 16GB physical RAM
Connected account of : Samuel Man
No plugin active
AUTO: /Volumes/Music Drive/
Library database path: /Users/samuelman/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Fingerprinting track 32296/45055 : /Volumes/Music Drive/-=Trance (1995-2003)=-/Art Bizarre - 69 (Plug’n’ Play Remix).mp3
Listening on 127.0.0.1 on port 61283
TIDAL: Connected as HiFi Plus
Local Audio Engine: CoreAudio
Exclusive access: ON
Integer mode: ON
iFi (by AMR) iFi (by AMR) HD USB Audio
UID:AppleUSBAudioEngine:iFi (by AMR):iFi (by AMR) HD USB Audio:0003:1
Selected device:iFi (by AMR) HD USB Audio
Manufacturer: iFi (by AMR)
Model name: iFi (by AMR) HD USB Audio
Model UID: iFi (by AMR) HD USB Audio:20B1:3008
UID: AppleUSBAudioEngine:iFi (by AMR):iFi (by AMR) HD USB Audio:0003:1
USB Vendor ID: 0x20b1
USB Product ID: 0x3008
ID 0x73
MQA Decoder device
Stream ID 0x74 2 channels starting at 1
32 virtual formats:
48 physical formats
2 ch Mixable linear PCM Interleaved 24 little endian Signed Integer 384kHz
2 ch Mixable linear PCM Interleaved 24 little endian Signed Integer 352.8kHz
Local devices found : 5
Device #0: ID 0x91 U32H85x
Model UID: AppleGFXHDA:0
UID: AppleGFXHDAEngineOutputDP:30001:0:{2D4C-0E3B-3052434D}
Model name: Apple Inc. U32H85x
Device #1: ID 0x73 iFi (by AMR) HD USB Audio
Device #2: ID 0x85 MacBook Pro Speakers
Model UID: Speaker
UID: BuiltInSpeakerDevice
Device #3: ID 0x4f Microsoft Teams Audio
Manufacturer: Microsoft Corp.
Device #4: ID 0x34 rekordbox Aggregate Device
Model UID: com.Pioneer DJ.rekordbox Aggregate Device
Model name: Apple Inc. rekordbox Aggregate Device
UPnP devices found : 2
Device #0: ID 0x0 : DLNA-Player-MediaCenter
UID: uuid:bda4efc0-db0c-41f8-b7d5-020000000000
Manufacturer: Amlogic Corporation
Model name: AV Renderer
Device #1: ID 0x0 : ATV_173
UID: uuid:898f9738-d930-4db4-a3cf-40aa560d76f5
Manufacturer: WaxRain
Model name: WaxRainPlayer
Chromecast devices found : 2
Device #0: Kitchen speaker
Model name: Google Home Mini
Device #1: Bedroom Display
Model name: Google Nest Hub
