Audirvana Mac Version 3.5.35 (3565)
macOS 10.15.4 with 16384MB RAM
AUTO: /Volumes/USB 3To/Musique
Library database path: /Users/Zork/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Schiit USB Audio Gen 2
Model UID:Schiit USB Audio Gen 2:0D8C:0004
UID:AppleUSBAudioEngine:Schiit Audio:Schiit USB Audio Gen 2:14300000:1
Device: 2ch Non-mixable linear PCM Interleaved 24bits little endian Signed Integer, 6 bytes per frame 96kHz
Active Sample Rate: 96kHz
Hog Mode is on
ID 0x29 Schiit USB Audio Gen 2 Manufacturer:Schiit Audio
Model UID:Schiit USB Audio Gen 2:0D8C:0004 UID:AppleUSBAudioEngine:Schiit Audio:Schiit USB Audio Gen 2:14100000:1
24 virtual formats:
36 physical formats
Device #0: ID 0x32 Sortie intégrée Manufacturer: Apple Inc. Model UID: AppleHDA:15 UID: AppleHDAEngineOutput:1F,3,0,1,1:0
Device #1: ID 0x29 Schiit USB Audio Gen 2 Manufacturer: Schiit Audio Model UID: Schiit USB Audio Gen 2:0D8C:0004 UID: AppleUSBAudioEngine:Schiit Audio:Schiit USB Audio Gen 2:14100000:1
