After Audirvana update login seemed to create new account? Fav and playlist empty - get error - unable to open an audio file for playback.
debug info added
Audirvana Mac Version 3.5.33 (3563)
macOS 10.13.6 with 8192MB RAM
Registered to Peter Black
Globally: ON
iZotope SRC with device max frequency upsampling iZotope SRC filter parameters
Steepness = 150
Filter max length = 500000
Cut-Off (x Nyquist) = 100%
Anti-aliasing = 200
Phase = 100%
Replay Gain: by track
Manual: /Users/peterblack/Library/Mobile Documents/com~apple~CloudDocs/.Trash/DSD Music Files
Library database path: /Users/peterblack/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
TIDAL: Connected as
iFi (by AMR) HD USB Audio Output
UID:AppleUSBAudioEngine:iFi (by AMR):iFi (by AMR) HD USB Audio:00000000:1
ID 0x27 iFi (by AMR) HD USB Audio Output Manufacturer:iFi (by AMR)
Model UID:iFi (by AMR) HD USB Audio:20B1:3008 UID:AppleUSBAudioEngine:iFi (by AMR):iFi (by AMR) HD USB Audio:00000000:1
MQA Renderer device
Stream ID 0x28 2 channels starting at 1
16 virtual formats:
16 physical formats
Local devices found : 4
Device #0: ID 0xc6 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:33 UID: AppleHDAEngineOutput:1B,0,1,2:0
Device #1: ID 0x27 iFi (by AMR) HD USB Audio Output Manufacturer: iFi (by AMR) Model UID: iFi (by AMR) HD USB Audio:20B1:3008 UID: AppleUSBAudioEngine:iFi (by AMR):iFi (by AMR) HD USB Audio:00000000:1
Device #2: ID 0x2a Soundflower (2ch) Manufacturer: ma++ ingalls for Cycling '74 Model UID: com_cycling74_driver_SoundflowerDevice:Soundflower UID: SoundflowerEngine:0
Device #3: ID 0x35 Soundflower (64ch) Manufacturer: ma++ ingalls for Cycling '74 Model UID: com_cycling74_driver_SoundflowerDevice:Soundflower UID: SoundflowerEngine:1
