I’ve connected to my tidal account but it’s not showing up at all.
![Screenshot 2022-01-03 at 08.08.51](https://community.audirvana.com/uploads/default/original/2X/4/4b15d74fcb8b01519af99d1fe4dec91d05b71014.png)
debug info:
Audirvana Studio 1.9.0 (10900)
macOS 11.6.1 with 32GB physical RAM
Connected account of : []
r8brain to DSD128 with filter type C
Replay Gain: by album
SW volume control: ON
AUTO: /Volumes/Data/Music/Stream
Library database path: /Users/kbhatt/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 63739
NAIM AUDIO NAIM - LIVING ROOM
Model UID:Naim Audio Naim - Living Room
UID:uuid:18f28750-f474-46fe-8ce9-640ce65d8fd7
Active Sample Rate: 48kHz
ID 0x51 MacBook Pro Speakers
Model Name: Apple Inc. MacBook Pro Speakers
Model UID: Speaker
UID: BuiltInSpeakerDevice
Stream ID 0x52 2 channels starting at 1
4 virtual formats:
4 physical formats
Local devices found : 3
Device #0: ID 0x66 HDMI Monitor Manufacturer: Apple Inc. Model UID: AppleGFXHDA:0 UID: AppleGFXHDAEngineOutputDP:10001:0:{AE1A-9D31-00000000} Model Name: Apple Inc. HDMI Monitor
Device #1: ID 0x5d USB PnP Audio Device Manufacturer: Unknown Manufacturer Model UID: USB PnP Audio Device:0C76:161F UID: AppleUSBAudioEngine:Unknown Manufacturer:USB PnP Audio Device:14143000:1 Model Name: Unknown Manufacturer USB PnP Audio Device
Device #2: ID 0x51 MacBook Pro Speakers Manufacturer: Apple Inc. Model UID: Speaker UID: BuiltInSpeakerDevice Model Name: Apple Inc. MacBook Pro Speakers
UPnP devices found : 5
Device #0: ID 0x0 Marantz SR7012 UID: uuid:c39faab3-1618-19a2-0080-0005cdf1c726 Location: http://192.168.1.144:60006/upnp/desc/aios_device/aios_device.xml
Device #1: ID 0x0 Marantz SR7012 UID: uuid:37446583-7c40-180e-0080-0005cdf1c726 Location: http://192.168.1.144:60006/upnp/desc/aios_device/aios_device.xml
Device #2: ID 0x0 Marantz SR7012 UID: uuid:17e1ba2f-b4a6-1713-0080-0005cdf1c726 Location: http://192.168.1.144:60006/upnp/desc/aios_device/aios_device.xml
Device #3: ID 0x0 Marantz SR7012 UID: uuid:7d6fb535-19f8-c2ab-29fe-c3c4e32f1f65 Location: http://192.168.1.144:60006/upnp/desc/aios_device/aios_device.xml
Device #4: ID 0x0 Marantz SR7012 UID: uuid:4c91e070-5d8a-979c-435b-bb37eebad88b Location: http://192.168.1.144:60006/upnp/desc/aios_device/aios_device.xml
