Audirvana 3.5.37
AUTO: M:
Library database path: C:\Users\Ian\AppData\Local\Audirvana\AudirvanaPlus\AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 4902MB
Local Audio Engine:ASIO 2 driver version 1091
S2 Digital (2- Pre Box S2 Digital)
Model UID:S2 Digital (2- Pre Box S2 Digital)
UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{2ea569f3-ae8d-4b58-bcb1-aa80b63edf70}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Pro-Ject Box ASIO Driver Manufacturer:
Model UID:Pro-Ject Box ASIO Driver UID:Pro-Ject Box ASIO Driver
2822400
5644800
11289600
22579200
DSD capability: Raw DSD (MSB)
Device #0: Pro-Ject Box ASIO Driver Manufacturer: Model UID: Pro-Ject Box ASIO Driver UID: Pro-Ject Box ASIO Driver
Device #1: Realtek ASIO Manufacturer: Model UID: Realtek ASIO UID: Realtek ASIO
UPnP devices found : 3
Device #0DMP-BDT220 UID: uuid:4D454930-0100-1000-8000-8CC12131B6C7 Location: http://192.168.1.6:60606/8CC12131B6C7/Server0/ddd
Device #1Moode UPNP UID: uuid:2dfea03c-6f8a-b387-b7bd-b827eb888fd7 Location: http://192.168.1.72:49152/description.xml
Device #2SR5007 UID: uuid:5f9ec1b3-ff59-19bb-8530-000678131a86 Location: http://192.168.1.14:8080/description.xml
