Hi,
I’ve bought a new Mac mini M1, installed Audirvana and I can’t use Tidal. I could log in Tidal, but Audirvana doesn’t load My Music properly (only some of it). If I click Generes and try to play anything the error is:
Unable to open an audio file for playback
Please help me! On my MacBook Pro I have no problem like this.
Debug info:
macOS 11.2.1 with 16384MB RAM
Registered to Gabor Bajor
Sync list: 0 folders
iTunes/Music library synchronization: last synchronized on Sun Feb 14 15:08:20 2021
Library database path: /Users/gabor/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
TIDAL: Connected as FREE
Max. memory for audio buffers: 5430MB
SA-10S1
Model UID:SA-10S1:154E:3008
UID:AppleUSBAudioEngine:D&M Holdings Inc.:SA-10S1:2100000:1
ID 0x2c SA-10S1 Manufacturer:D&M Holdings Inc.
Model UID:SA-10S1:154E:3008 UID:AppleUSBAudioEngine:D&M Holdings Inc.:SA-10S1:2100000:1
Audio buffer frame size : 116 to 4096 frames
Stream ID 0x2d 2 channels starting at 1
30 virtual formats:
40 physical formats
Local devices found : 3
Device #0: ID 0x35 LG TV Manufacturer: GSM Model UID: 1E6D0100-0000-0000-0117-010380A05A78 UID: 1E6D0100-0000-0000-0117-010380A05A78
Device #1: ID 0x2c SA-10S1 Manufacturer: D&M Holdings Inc. Model UID: SA-10S1:154E:3008 UID: AppleUSBAudioEngine:D&M Holdings Inc.:SA-10S1:2100000:1
Device #2: ID 0x44 Mac mini Speakers Manufacturer: Apple Inc. Model UID: Speaker UID: BuiltInSpeakerDevice
